Greetings!
I own a bunch of Tamiya RC Tanks among them two whose Road Light Effects are being emitted inside the Tank using an SINGLE LED whose Light then gets split and redirected outside into the Light Buckets using Fiber Optic like clear "Filament".
For the purpose of better results I'm planning on replacing this mildly unreliable System ( over the years the Fiber Optics have turned brittle, started breaking, and thus have stopped passing through the LED Light ) with dedicated LED's inside the Light Buckets in most cases DOUBLING up the LED Count attached to the wiring of the respective Tamiya DMD Controller.
How should I go about this for the best results while ensuring the DMD Controllers not be at risk?
- Can I simply add a 2nd LED where necessary without doing anything Resistor related? ( there's no Resistor to be found on the PCB housing the LEDs - Probably all inside the DMD )
- Should the LED's be run in Parallel or Series? ( again, in regards of not causing any electrical harm to the existing DMD Configuration )
