Can you bind a HL 2.4GHz 7.0 transmitter to TK 7.1 receiver and have all the functions of the TK 7.1 work as designed?
Binding HL 2.4GHz 7.0 transmitter to TK 7.1 receiver
There is a 7.1 transmitter! Me and Hugo each have one.
It has one more function on the remote hidden as a trim switch to control a periscope or some sort of rotation motor. It is otherwise using the same frequencies and is outwardly appearing the same as a standard 7.0 controller.SoCal RC Tank Club Facebook Group
Gathering 1-2x monthly/All Ages & Experience levels welcomeComment
Wow, a stealth 7.1! So that’s how David’s Abram activates the periscope rotation. Now that I think of it, that command is in the 7.0/7.1 instruction sheet. Otherwise externally identical?
Edit: I see Amazon has a 7.1 transmitter advertised! The trim tabs are actually movable, not fixed as in 6.0 & 7.0.The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
Glad to hear about the missing function using the 7.0 transmitter with the 7.1 receiver.
Well, since I want to use ALL the features of my HL TK 7.1 receiver on my HL Merkava MK IV, I ordered a new HL 2.4GHz 7.1 transmitter radio from Toucan in NJ today.Comment
The 7.1 receivers have a lot of circuit sockets that aren’t used under normal circumstance by 7.0 tx’s……up til now! Apparently the new Abrams has a rotating periscope and a remote control hatch operated by the new 7.1 tx. I wonder if there are more tank function surprises coming. Anybody found any in the Merkava?The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
