T90 suspension not compressing when going backwards
  • T90 suspension not compressing when going backwards
    I recently bought a T90 Heng Long (Amewi) that came with everything in metal. I took it out to test the suspension and I noticed that going forward the suspension acted as expected but in reverse only some of the suspensions compressed. I would like to ask if anyone else also had this problem, for me it's not a major factor but I would like to ask some tips on how to fix this.
    Thanks in advance,
    Thanks in advance,
    Assuming everything was installed correctly. Sounds like your track tension is a bit high or it could be that some of the suspension springs were installed at the higher spring tension setting. Possible it could also be a combination of the two as well.
      I found the problem and it was related with the arm being screwed on too tight from the factory, now it works like a charm. Anyway, thank you Rubicon for your advice though!
