T34/76 1943 "Micky Mouse" turret
  • tank_me
    • Feb 2022
    • 1197
    I almost feel like this is going to be an unofficial New Years resolution for me this year...clear out the backlog of old builds. I've got so many old builds piled up that I felt like it was time to do something about it. I grabbed the most complete tank build I had and decided to finish it. It just happened to be the Trumpeter T34/76 1943 conversion built on a Taigen T34 lower. It doesn't have it's own build thread here as I started it way before being a member here, you guys will just have to catch up with this posting.
    Previously the tank has had magnets added to the turret halves, magnet mounts were built for the upper hull to mount to the lower hull, bearings were added to the kit wheels, the Trumpeter upper deck was adapted to the Taigen lower, a Henntec adjustable idler was added, a Visaton FRS7 speaker installed, a Clark TK50 installed, a HL rotation unit adapted to the Taigen rotation gear via a custom mounting solution, and a custom recoil/elevation built from some aluminum angle/servos.
    Magnet mounts for the hull:
    Speaker box that also acts as a hull brace. I can be easily removed if needed.
    Rotation mounting:
    Completed lower next to it's sibling - the 1942 T34/76 with applique armor.
    With those pics you should be caught up.
    The tank was pretty well complete except for wiring issues. I finished the wiring on the turret rotation, the spot light, the IR LED (mounted below the gun), and the MG LED. I also mounted the 3D printed apple base in one of the hatches. I lowered it enough that I can still put the hatch on when the apple isn't installed. I will be adding a small magnet to the hatch and one on the mount to keep the hatch in place. Russian hatches of this era weren't designed to open fully so removing it was kinda the best option for when the apple is needed for battle.
    After the wiring was complete I tested all it's functions and ran it around on the carpet for a few minutes. The barrel position wasn't right for some reason so I adjusted both the servo recoil arm and the elevation servo. I then did a functions check and verified all functions were working on the Clark TK50. You can see the barrel elevation and depression is pretty good now.
    Some additional texture was added to the tank on the turret and the MG port as the factory texture in the plastic was a little too consistent. There were a few details that got knocked off during the build like one of the lifting eyes on the turret and the turret hatch stops. All were reinstalled. I put the weld lines in around the towing hooks, the turret air cleaner, and along the mantlet sides. Most of the other weld lines were already present on the tank. They are small, but there none the less. I kinda forgot to get pics of that stage as it is a tad rougher than just the Mr. Surfacer that is on it in the pics.
    With so many T34 variants laying around, I decided I needed to mix and match some of the dished road wheels along with the steelies and spoked wheels. They will be grouped on the front right of the tank together. I figured if the tank was hit it's possible both of those wheels took damage and got replaced with whatever was on hand. The wheels that were replaced will be distributed to the T34/76 1942 tank and my SU-122.
    And then with great enthusiasm...paint. I actually really hate the painting stage, but since this project has gone so long it was good to see it all in one color. It's now off to the side to cure.
    This is the set of decals I will be using. I will be adding the camo pattern as well. When this one is finished I was going to tackle it's sibling, but it seems the sound has died on it's TK50 and there are other mechanical issues to sort out with the turret elevation. Those things will have to wait as there are other vehicles with less issues that can be knocked out first. Gonna get all that low hanging fruit first.
    That's all for now...​
  • tank_me
    • Feb 2022
    • 1197
    And it's inching closer to being complete. Camo on and markings on. Markings are a combo of painted (smaller numbers and slogan) and decals (crest, star, large 106). Did a few 4BO touch ups tonight so I'm letting them dry before clear coating. I will probably do a light weathering, but maybe I'll just let it weather on it's own.
    • tank_me
      • Feb 2022
      • 1197
      The markings and camo are based on a real vehicle as I found a pic of it and it's crew. It seems the slogan means, "Stalinets". The slogan is probably based on where the tank was made. Russia produced Stalinets S60 (Russian: Сталинец-60) and S65 tractors at the Chelyabinsk Tractor Plant between 1933 and 1937.
      From Wikipedia:
      During World War II seven other industrial entities (including most of Leningrad's Kirov Plant and 15,000 of its workers) were either wholly or partially relocated to Chelyabinsk, the resulting enterprise commonly known as "Танкоград" ('Tankograd', or 'Tank City'). The work force increased to 60,000 workers by 1944, from 25,000 during non-military production; during the conflict the works produced 18,000 tanks, and 48,500 tank diesel engines as well as over 17 million units of ammunition. Production included the KV tank from 1941, T-34 tank from 1942, KV-85 tank and IS tanks from 1943, and T-34/85 tank and SU-85 self-propelled field gun from 1944. By 1945 the plant had been awarded the Order of Kutuzov, 1st Class, the Order of Lenin, the Order of the Red Star, and other honors for its efforts in helping to defeat Nazi Germany.​​
      • tank_me
        • Feb 2022
        • 1197
        I'm calling this project done. Got the magnet mounted in one of the Mickey Mouse ears so that it can be removed to add the apple when needed and hide the mount when not.
        Click image for larger version  Name:	ZF30Qnl.jpg Views:	0 Size:	133.4 KB ID:	407803
        Click image for larger version  Name:	H06OhdZ.jpg Views:	0 Size:	116.7 KB ID:	407804
        Tracks are back on and she's ready for battle. I did add a little bit of panel liner and weathered the decals just a tad so that they weren't so much in your face bright.
        Click image for larger version  Name:	dU707YA.jpg Views:	0 Size:	139.0 KB ID:	407805
        I did stack two of the solid wheels on the front of the tank to simulate a wheel replacement. I thought that was a logical location for a tank to be hit. The other wheels will be mounted on my other T34/76 project.
        Click image for larger version  Name:	f0aiQFP.jpg Views:	0 Size:	107.8 KB ID:	407807
        I had it out to our new battlefield in Texas and it performed flawlessly. Well flawlessly after I removed the cotton I had stuck in the emitter tube for painting. Forgot to get pics of it running around the field.
        That's it for this build...for now. Never know, it might get some 76mm ammo crates or something in the future.
        • SoCalBobS
          • 2754
          • Southern California
          Looks great!
          • SoCalBobS
            • 2754
            A progress report post on mine. I was going to install the square rear gas tanks, but I ended up preferring the look of the side square ones. I placed two headlights on the glacis in place of the one side mount. And the spot light as I'd mentioned before. Nearing completion.
ID:	407882 Click image for larger version
            • Rubicon99
              • 3316
              Looking good👍👍
              • tank_me
                • Feb 2022
                • 1197
                The early side tanks are definitely less common. Looks the part. I can't wait until the early T34 is available to purchase from Ram over on RC Tank Warfare. It's even got the early patterned tracks.
