Official Tongde US M2A2 Bradley 1/16 Scale IFV Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	tongde-us-m2a2-bradley-upgrade-edition-1-16-scale-ifv-rtr-motion-rc-35194394214585.jpg
    The specs and images shown are for the upgrade edition. The professional edition comes with metal upgrades and can be found here.
    Motion RC is pleased to offer Tongde RC tanks and IFV’s to global RC tankers! Offering unique subjects, these models are available in similar versions to other familiar manufacturers. When combined with Motion RC’s industry-leading selection, parts support, and customer service, Tongde RC models deliver an unbeatable value for RC armor enthusiasts.
    The M2A2 Bradley Infantry Fighting Vehicle is designed to transport and protect an infantry squad against small arms fire, while delivering enough firepower to eliminate hostile threats. Fast and highly maneuverable, the Bradley has a crew of three and capacity to carry six fully outfitted combat soldiers. Equipped with an M242 25mm automatic cannon and TOW anti-tank missile launcher, the Bradley has been proven combat-capable of disabling enemy armor or destroying softer targets.
    This upgrade version offers nylon tracks and road wheels for light weight and budget friendliness, while delivering an extensive feature list that includes LED lights, sound, IR battle system (compatible with other brands), and more. All of Motion RC’s Tongde 1/16 scale tanks utilize the latest TD 2.0 MFCB (Multi-Function Control Board) for outstanding control, performance, playability, and upgrade potential!
    Note: This model does not offer airsoft BB launch.
    Ready to Run
    Each Tongde model arrives "Ready to Run" (RTR) to allow enthusiasts to join the exciting world of RC Armor quickly and easily!
    Compact and Efficient Gearboxes
    Tongde Upgrade models feature lightweight, economical nylon gearboxes while Professional versions include a metal-geared unit.
    Easy Access Operation
    The Tongde M2A2 features a convenient hatch in the hull front that allows for convenient charging or powering up.
    Impressive Scale Details
    The M2A2 is impressively outfitted with an array of factory-painted, easily installed supplemental plastic detail parts.
    • Latest generation TD 2.0 Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed/ low speed modes, etc.
    • Adjustable track tension
    • Smoke effect (on/off)
    • LED lights (on/off)
    • Sound effects volume
    • Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
    • Track recoil
    • Fires an invisible IR signal to be used as part of Tongde’s Infrared Battle System, which disables other tanks when hit five times during simulated combat.
    • Torsion bar suspension
    • Tongde US M2A2 Bradley Upgrade Edition 1/16 Scale IFV - RTR
    • 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
    • 2S USB LiPo/Li-ion battery charger
    • 12 channel 2.4GHz radio transmitter
    • Magnetic infrared (IR) battle system receiver
    • Painted cosmetic accessory parts
    • Adhesive decal sheet
    • Smoke oil
    • Comprehensive instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 1 Hour
    Scale 1:16
    Length 44cm / 17.1in
    Width 20.8cm / 8.1in
    Height 20cm / 7.8in
    Weight 2,725g / 97oz
    Body Material ABS plastic
    Chassis Material ABS plastic
    Track Material Plastic
    Bearings Metal bushings
    Gearbox Gear Material Plastic
    Adjustable Gear Ratio No
    Differential Type N/A
    Suspension Type Torsion bar
    Sprocket Plastic
    Road Wheels Plastic
    Idler Wheel Plastic
    Adjustable Idler Yes
    Turret Rotation 320 degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil No
    Required Battery 2S 7.4V 1800mAh Li-ion battery with Tamiya connector (included)
    Required Radio 12 channel 2.4GHz (included)
    Skill Level Beginner
    Build Time 1 hour
    Recommended Environment Indoor / outdoor
