I broke down and bought a Merkava. Toucan had them for $70 off the normal price for the all metal (minus the hull) version. I already started trying to build a cope cage for it as seen in the recent conflict:
So I found one on Cults3D to print:
Unfortunately no matter what material I tried to print it in, it failed to print in either version. Tried it in ASA, PETG, and ABS like resin. The mesh or the bar version was just modeled too delicately to print right in 1/16 scale. The bars and mesh got distorted as it would detach from the resin printer's FEP or the supports on the FDM printer were too difficult to remove eventually breaking the bars or the mesh. At that point, I took the bad PETG print, cut out all the center sections, found a free scalable plastic grill mesh on Printables, printed it out, cut out the sections I needed and glued them to the cope cage. As you can see, even a few of the squares broke getting off the build plate as they are like less than a mm high.
This is the result I got:
Next steps...finish mounting the cope cage legs and replacing the fake rubber skirts with real silicone rubber skirts (or TPU).
