Tongde M2A2 Bradley IFV question
  • EvilMP
    • Jan 2021
    • 18
    Hi,
    I just got my Tongde M2A2 Bradley from Motion RC and started to put it together after testing some of the functionality. After completing the assembly I noticed something off with the TOW module I didnt catch the first go over. The hinge pin isn't seated correctly and keeps backing out of the hinge assembly, it appears to be one of those pins that are pressed on each end. I am not even sure if I could just find a long RC bolt that thin. I also noticed the TOW doesn't fully extend to the top position fully. And the guide rod when it gets to the almost to the top fully opened position, the guide rod for the TOW pops out of the guide track. Not to sure on how to correct this issue. I watched a YT video where another guy was talking about the servo being a weak one that doesn't fully engage the TOW, needless to say because of that his servo overheated and melted a bit. If the option is to replace it what micro servo should I use that will still work with the factory transmitter?
    Another thing the manual tells you that you can add a servo to automate the back drop hatch. But no servo is listed for compatibility with the stock transmitter. So frustrating, so many issues straight out of the box!
