Official Tongde UK Churchill Mk. VII 1/16 Scale Battle Tank Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Motion RC is pleased to offer Tongde RC tanks newest release, the Churchill MK VII. Offering unique subjects, Tongde models are available in similar versions to other familiar manufacturers. When combined with Motion RC’s industry-leading selection, parts support, and customer service, Tongde RC models deliver an unbeatable value for RC armor enthusiasts.
    The UK Churchill Mk. VII tanks were originally designed and produced toward the end of WWII. Known as the “Heavy Churchill”, the MK VII used a 75mm gun and carried armor twice as thick as that used on a German Tiger I, allowing the Churchill to absorb massive amounts of punish while continuing to fight. The MK VII first saw service in the Battle of Normandy, along the Western Front in Europe, in Italy, and lastly in Korea.
    Note: This model does not offer an airsoft BB launch function
    This upgrade version offers nylon tracks and road wheels for light weight and budget friendliness, while delivering an extensive feature list that includes LED lights, sound, IR battle system (compatible with other brands), and more. All of Motion RC’s Tongde 1/16 scale tanks utilize the latest TD 2.0 MFCB (Multi-Function Control Board) for outstanding control, performance, playability, and upgrade potential!
    Outstanding Realism
    Although each Tongde model arrives "Ready to Run" (RTR) to allow enthusiasts to join the exciting world of RC Tanks quickly and easily, there is no shortage of scale details for unsurpassed accuracy and realism.
    IR Capable
    The socket for included IR bulbs’ connector is safely housed behind a hatch to protect from dirt and debris when not in use.
    Realistic Track and Drive System
    Like the real Churchill, the Tongde MK VII 1/16 scale replica features 11 bogies wheels. With individual springs on each pair, the suspension system allows for aggressive climbing and fording maneuvers as with the 1:1 tank.
    Easy Battery Access
    A convenient hatch allows easy access to the included battery pack.
    • Latest Generation TD 2.0 Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed/ low speed modes, etc.
    • Adjustable track tension
    • Smoke effect (on/off)
    • LED lights (on/off)
    • Sound effects volume
    • Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
    • Track recoil
    • Fires an invisible IR signal to be used as part of Tongde’s Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other
    • Spring/Trolley arm suspension
    • Tongde UK Churchill Mk. VII Upgrade Edition 1/16 Scale Battle Tank - RTR
    • 2S 7.4v 1800mAh Li-ion battery with Tamiya connector
    • 2S USB LiPo/Li-ion battery charger
    • 12-channel 2.4GHz radio transmitter
    • Magnetic infrared (IR) battle system receiver
    • Plastic cosmetic accessory and detail parts
    • Adhesive decal sheet
    • 6mm plastic BBs (50 Pack)
    • Smoke oil
    • Comprehensive instruction manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 1 Hour
    Scale 1:16
    Length 44.5cm / 17.4in
    Width 18.5cm / 7.3in
    Height 15.8cm / 6.2in
    Weight 3,350g / 119.6oz
    Body Material ABS plastic
    Chassis Material ABS plastic
    Track Material Plastic
    Bearings Metal bushings
    Gearbox Gear Material Plastic
    Adjustable Gear Ratio No
    Differential Type N/A
    Suspension Type Spring/Trolley arm
    Sprocket Plastic
    Road Wheels Plastic
    Idler Wheel Plastic
    Adjustable Idler Yes
    Turret Rotation 320 degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V 1800mAh Li-ion battery with Tamiya connector (included)
    Required Radio 12 channel 2.4GHz (included)
    Skill Level Beginner
    Build Time 1 hour
    Recommended Environment Indoor / outdoor
