My M109A2
  • DavidN
    • May 2021
    • 3189
    • Los Angeles, CA
    My M109A2
    Click image for larger version  Name:	IMG_6910A.jpg Views:	6 Size:	362.5 KB ID:	414815 Click image for larger version  Name:	IMG_6903AA.jpg Views:	5 Size:	300.9 KB ID:	414816 Click image for larger version  Name:	IMG_6907A.jpg Views:	4 Size:	334.8 KB ID:	414817
    After playing around with this howitzer, I have decided to take its 3.0 board out and installed it into my Tongde M60 for IR battle purpose. The Tongde M60 is now battling just like the HL. I took the 2.0 board from the M60 and installed it into the M109A2 for playing it with the bb airsoft. There was no need to switch the transmitter. The Tongde transmitter works on both 2.0 and 3.0. I enjoyed very much playing with this howitzer in my backyard. It shot very high. I have some extra accessories from the Bradley. So I added them onto this one. I used all the decals that were in the box. It is Egyptian.
  • DavidN
    • May 2021
    • 3189
    • Los Angeles, CA
    • keilau
      • Mar 2021
      • 1815
      • Windy City
      Does the Tongde M109A2 have torsion bar suspension?
      • DavidN
        • May 2021
        • 3189
        • Los Angeles, CA
        Yes! They are quite weak.
        • RichJohnson
          • 1276
          Get some little red darts and shoot them up in the air
          • keilau
            • Mar 2021
            • 1815
            • Windy City
            The Tongde torsion bar being too weak for the all metal version is pretty well documented. 2 remedy were proposed to reduce the total weight of the RC tank:
            1. Replace the metal track with the plastic track.
            2. Use plastic road wheels with ball bearing.
            Personally, I like the TD metal track much better than the plastic track so I prefer the plastic road wheel solution. It works very well on my M60A1.
            • RichJohnson
              • 1276
              Road wheels do not factor into weight on the tortion bars as they are un sprung weight. They factor into traction and aversion as they do exert weight on the track but not in the suspension of the tank. Metal wheels likely won’t make a difference in how it feels driving with metal tracks.
              • keilau
                • Mar 2021
                • 1815
                • Windy City
                The RC tank suspension, torsion bar or coil spring, does not work that way.
                • RichJohnson
                  • 1276
                  Of course they do.
                  The weight of the wheels does not effect the weight of the tank on the suspension because they are below the suspension.
                  The weight of the wheels will only effect weight on the ground. The factor they will effect is ground pressure and therefore traction and turning and climbing ability.
                  • keilau
                    • Mar 2021
                    • 1815
                    • Windy City
                    Of course they do.
                    I just added metal road wheels to the Heng Long German Leopard 2A6 with no change to other components. I have to adjust the suspension coil spring to lift the Leo to its original plastic wheel height level. I use the Tamiya hybrid tracks. Road wheels, sprocket and idler wheel are Mato.
                    I just finished the metal road wheel upgrade on a 2021 Heng Long German Leopard 2A6. The original coil springs seem to be too weak for the new chassis weight of 11 pounds. Anyone knows a source for the right stronger coil spring? My Pro version HL Leopard came with metal suspension arm, but the arm axles have undersized OD for
                    I also added metal road wheels to the Heng Long Russian T-34/85. I removed 17 ounces of the dry weights to the T-34 after installing the metal wheels. It restores the balance and lift the tank to original height.
                    ​ My latest T-34/85 metal upgrade: Mato metal road wheel set Of the 2 Russian T-34/85 metal road wheel set on the market, I prefer this Mato one based on past experience. The cast is crisp and well defined. It comes with rubber tires making it easy to remove for painting the wheels. Each wheel comes with 2 ball bearings of 5mm
                    We must remember that weight is a scalar quantity and does not act as forces.
                    • Rubicon99
                      • 3311
                      There is a big difference between "sprung" and "unsprung" weight. Road wheels fall into "unsprung" weight. It's just that simple.
                      • keilau
                        • Mar 2021
                        • 1815
                        • Windy City
                        I am just talking about basic terms in physics. Weight is a static term in mechanics, not dynamic. The qualifier for "weight" is beyond my comprehension.
