HL 6.0S Abrams trigger no longer works
  • HardRock
    • Feb 2021
    • 28
    The trigger switch on my HL 6.0S Abrams no longer works. MG, lights, barrel elevation, turret rotation, sound and everything else still works fine and everything appears to be connected properly.
    What am I missing? Could it be a transmitter issue?
  • Rubicon99
    • 3316
    You could have inadvertently turned it off. Check your manual to see and do a system restart back to factory settings.
    If that is not the problem then replace the 6.0 system with a new 7.0.
    • tank_me
      • Feb 2022
      • 1197
      Does it have the BB shooter in it? If so, the micro switch could be bad. I think you could test that by using a jumper on the CN6 port. Just connect the pins together and try to fire the gun.
      Those of us that remove the BB function have to do that to get the tank to fire without the microswitch installed.
