TORRO Tiger 1
  • Kody
    • Jan 2025
    • 3
    TORRO Tiger 1
    Tank tiger 1, Torro, I replaced both servos in the turret, the recoil works fine, but the cannon lift is acting up: the lift angle is small, when I turn on the tank, the cannon lifts up by itself, and when I turn it off, it lowers down by itself, does anyone know where the problem is?
  • quitcherbitchen
    • 928
    • Altadena, CA
    Clark Board MFU? Sounds pretty normal. All my Clark boards do that.
    • tank_me
      • Feb 2022
      • 1197
      Do you have the Clark TV remote and the IR receiver to program it? If you don't have the remote, the default setting for elevation is ESC (IE: motor) and not PWM (IE: servo). If you don't change the setting the board to PWM/servo, it will not operate correctly. With it set to ESC/motor and having a servo connected it will do all kinds of crazy things.
      • quitcherbitchen
        • 928
        • Altadena, CA
        I think Tank_me might be correct. The board with the jerkyness of the servos is usually indicative of the board needing a reprogram. Clark Boards are really nice and I run them in all my tanks, but be prepared to have to learn how to program them. My only trick is to cycle the selections till you get the flash sequence you want. I know that means nothing to someone you hasn't done anything with a Clark board before, but it is the only trick that has helped my Clark Boards remember what I programmed. When you get to getting a programmer check back in.
