Official Mato German Panzer III Metal 1/16 Scale Medium Battle Tank Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	mato-german-panzer-iii-grey-metal-1-16-scale-medium-battle-tank-rtr.webp Views:	0 Size:	71.2 KB ID:	419286
    The German Panzer III, officially the Panzerkampfwagen III, was a medium tank pivotal to early German battlefield successes during World War II. Designed in the 1930s, it was intended to counter enemy tanks and complement the Panzer IV which primarily focused on infantry support. The Panzer III featured a 37 mm KwK 36 L/45 gun in early versions, later upgraded to a more effective 50 mm KwK 38 or KwK 39 to match evolving battlefield threats.
    Weighing around 20 tons, the Panzer III was powered by a 300-horsepower Maybach engine, enabling a top speed of approximately 40 km/h. Its suspension system provided good mobility across varied terrain, making it versatile for different combat scenarios. Early models had 15 mm of armor, later increased to 50 mm or more to improve survivability.
    The Panzer III was extensively used during the invasions of Poland, France, and the early stages of Operation Barbarossa. However, as Soviet T-34s and KV tanks emerged, the Panzer III’s firepower and armor was proven inadequate. By 1943, it was largely replaced by the Panzer IV and Panther in frontline roles, but it continued to serve in secondary roles, such as reconnaissance and command vehicles. Its reliability and balanced design made it a cornerstone of early German armored warfare.
    Mato tanks are the ultimate expression of 1/16 scale, all-metal, handcrafted RC tank models. Delivered in a custom-crafted aluminum carrying case, each Mato tank offered by Motion RC contains an extensive list of premium upgrades, including a Flysky 10 channel transmitter, Clark TK50S MFCB, metal tracks, wheels, and sprockets, LED lights, sound system, 360-degree turret rotation, Heng Long and Tamiya-compatible IR battle system, cannon barrel recoil, exhaust smoke system, cannon flash, adjustable track tensioners, 5:1 ratio steel gearboxes, adjustable sound effect volume, realistic torsion bar suspension and more!
    Metal Gearboxes
    The 5:1 ratio metal gearboxes provide powerful operation and optimum durability for an unsurpassed scale-realistic RC model tank experience.
    Handmade, Not Mass-Produced
    Each Mato tank is individually fabricated and assembled by skilled factory artisans, resulting in a one-of-a-kind replica that will delight RC armor enthusiasts.
    Custom Carrying Case
    Each Mato tank is delivered in a custom-crafted, durable aluminum case, perfect for secure storage and transportation.
    All Metal Construction
    Mato tanks feature meticulously handcrafted metal hulls, chassis, and tracks. The Panzer III contains a torsion bar suspension system for scale realism and performance.
    Premium Control
    All Mato tanks offered by Motion RC contain an upgraded 10-channel Flysky transmitter and Clark TK50S Multi-Function Control Board (MFCB).
    Individualized Serial Number
    Every Mato tank contains a unique VIN to provide customers with individualized support and technical assistance when required.
    Unsurpassed Scale Realism
    Mato leaves no detail behind, resulting in a model at home on display or at the battlefield.
    360° Turret Rotation
    All Mato tanks feature complete, 360 degree turret rotation for scale realism and battlefield convenience.
    • 100% handcrafted from metal by skilled factory artisans
    • Factory painted-ready for graphics and weathering
    • Aluminum carrying case for convenient storage and transportation
    • Advanced Flysky 10-channel 2.4GHz transmitter
    • Clark TK50S Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for recoil, turning control, throttle feel, high speed and low-speed modes, etc.
    • Exhaust smoke effect (on/off)
    • Headlights (on/off)
    • Selectable sound sets with unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound with variable volume
    • Adjustable track tension
    • Track recoil - This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other (compatible with Heng Long and Tamiya IR Battle Systems)
    • Torsion bar suspension with metal tracks, sprockets, idlers, and road wheels
    • Mato German Panzer III Grey Metal 1/16 Scale Medium Battle Tank - RTR
    • 2S 7.4v 3000mAh Li-ion battery with Tamiya connector
    • 2S LiPo/Li-ion battery charger
    • Flysky 10-channel 2.4GHz radio transmitter
    • Infrared (IR) battle system receiver
    • Smoke oil
    • Owner’s manuals
    • Custom aluminum carrying case
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 30 Minutes
    Scale 1/16
    Length 390mm / 15.4in
    Width 185mm / 7.3in
    Height 170mm / 6.7in
    Weight 4,500g / 160.7oz
    Body Material Metal
    Chassis Material Metal
    Track Material Metal
    Motors 380 motors x2
    Bearings Ball bearings
    Gearbox Gear Material Metal
    Adjustable Gear Ratio No
    Differential Type N/A
    Suspension Type Torsion bar
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler Yes
    Turret Rotation 360 degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V (included)
    Required Radio 2.4GHz (included)
    Skill Level Beginner
    Build Time 30 minutes
