Official Mato German Tiger I Metal 1/16 Scale Heavy Battle Tank Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	mato-german-tiger-i-grey-metal-1-16-scale-heavy-battle-tank-rtr.webp Views:	0 Size:	68.5 KB ID:	419290
    Click image for larger version  Name:	mato-german-tiger-i-desert-yellow-metal-1-16-scale-heavy-battle-tank-rtr.webp Views:	0 Size:	62.9 KB ID:	419291
    Click image for larger version  Name:	mato-german-tiger-i-unpainted-metal-1-16-scale-heavy-battle-tank-rtr.webp Views:	0 Size:	86.8 KB ID:	419292
    The German Tiger I tank was one of the most iconic and formidable armored vehicles of World War II. Officially designated the Panzerkampfwagen VI Tiger Ausf. E, it was introduced in 1942 and became a symbol of Nazi Germany's technological prowess on the battlefield. Designed to counter increasingly well-armored Allied tanks like the Soviet T-34, the Tiger I boasted a thick armor plating of up to 120mm and a highly effective 88mm KwK 36 L/56 gun, capable of destroying enemy tanks at long ranges. The Tiger I's engineering was advanced for its time, providing exceptional firepower and protection. However, its complexity came at a cost. It was expensive to produce, with only about 1,350 units built, and its heavy weight of 57 tons limited mobility, reliability, and fuel efficiency. Breakdowns were common, and logistical challenges often hampered its effectiveness in the field.
    Despite these issues, the Tiger I achieved legendary status due to its battlefield performance. Crewed by well-trained tankers, it struck fear into Allied forces, becoming a symbol of German military might. However, by 1944, its limitations in quantity, production costs, and adaptability meant it was overshadowed by more modern designs like the Panther and Tiger II.
    Mato tanks are the ultimate expression of 1/16 scale, all-metal, handcrafted RC tank models. Delivered in a custom-crafted aluminum carrying case, each Mato tank offered by Motion RC contains an extensive list of premium upgrades, including a Flysky 10 channel transmitter, Clark TK50S MFCB, metal tracks, wheels, and sprockets, LED lights, sound system, 360-degree turret rotation, Heng Long and Tamiya-compatible IR battle system, cannon barrel recoil, exhaust smoke system, cannon flash, adjustable track tensioners, 5:1 ratio steel gearboxes, adjustable sound effect volume, and more! Model-specific features of this Tiger I also include cannon smoke, realistic torsion bar suspension system, and a painted grey finish ready for your application of graphics or weathering (if desired).
    Premium Control
    All Mato tanks offered by Motion RC contain an upgraded 10-channel Flysky transmitter and Clark TK50S Multi-Function Control Board (MFCB).
    360° Turret Rotation
    All Mato tanks feature complete, 360 degree turret rotation for scale realism and battlefield convenience.
    Handmade, Not Mass-Produced
    Each Mato tank is individually fabricated and assembled by skilled factory artisans, resulting in a one-of-a-kind replica that any RC tanker will be proud to own and operate.
    Impressive LED Light System
    The Tiger I features an extensive LED system to replicate muzzle flash, machine gun flash, headlights, and more.
    All Metal Construction
    Mato tanks feature meticulously handcrafted metal hulls, chassis, and tracks. The Tiger I contains a torsion bar suspension system for scale realism and performance.
    Easy Access
    The Tiger I features a convenient rear hatch to provides access for powering the model on/off and charging the included battery pack.
    Custom Carrying Case
    Each Mato tank is delivered in a custom-crafted, durable aluminum case, perfect for secure storage and transportation.
    Detachable Skirts
    The Mato Tiger I includes detachable side skirts for battle-specific supremacy!
    • 100% handcrafted from metal by skilled factory artisans
    • Version-specific grey painted finish-ready for your graphics and weathering
    • Aluminum carrying case for convenient storage and transportation
    • Advanced Flysky 10-channel 2.4GHz transmitter
    • Clark TK50S Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for recoil, turning control, throttle feel, high speed and low-speed modes, etc.
    • Exhaust smoke effect (on/off)
    • Headlights (on/off)
    • Selectable sound sets with unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound with variable volume
    • Adjustable track tension
    • Track recoil - This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other (compatible with Heng Long and Tamiya IR Battle Systems)
    • Torsion bar suspension with metal tracks, sprockets, idlers, and road wheels
    • Mato German Tiger I Grey Metal 1/16 Scale Heavy Battle Tank - RTR
    • 2S 7.4v 3000mAh Li-ion battery with Tamiya connector
    • 2S LiPo/Li-ion battery charger
    • Flysky 10-channel 2.4GHz radio transmitter
    • Infrared (IR) battle system receiver
    • Smoke oil
    • Owner’s manuals
    • Custom aluminum carrying case
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 30 Minutes
    Scale 1/16
    Length 520mm / 20.5in
    Width 240mm / 9.4in
    Height 190mm / 7.4in
    Weight 7,500g / 267.8oz
    Body Material Metal
    Chassis Material Metal
    Track Material Metal
    Motors 380 motors x2
    Bearings Ball bearings
    Gearbox Gear Material Metal
    Adjustable Gear Ratio No
    Differential Type N/A
    Suspension Type Torsion bar
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler Yes
    Turret Rotation 360 degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V (included)
    Required Radio 2.4GHz (included)
    Skill Level Beginner
    Build Time 30 minutes
