Official Mato USA M10 Metal 1/16 Scale Tank Destroyer Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	mato-usa-m10-unpainted-metal-1-16-scale-tank-destroyer-rtr.webp Views:	0 Size:	92.6 KB ID:	419350
    The M10 Tank Destroyer was a versatile and widely used American armored vehicle during World War II. Designed to counter heavily armored German tanks, it combined mobility, firepower, and ease of production. The M10 was built on the M4 Sherman chassis and was armed with a powerful 3-inch (76.2 mm) M7 gun, capable of penetrating the armor of most German tanks when properly employed.
    The M10 featured a lightly armored, open-topped turret, prioritizing weight reduction and cost-efficiency. While this design improved visibility and allowed for rapid reloading, it left the crew vulnerable to small arms fire and artillery shrapnel. The vehicle's sloped armor offered some protection but was insufficient against direct hits from high-caliber weapons. Powered by a 375-horsepower General Motors diesel engine, the M10 had a top speed of around 30 mph (48 km/h), making it more mobile than many of its counterparts. Deployed in Europe, North Africa, and the Pacific, the M10 often relied on speed and flanking maneuvers to engage enemy tanks effectively. Although the M10 was highly valued for its adaptability and firepower, it was eventually replaced by more advanced tank destroyers like the M36 Jackson.
    Mato tanks are the ultimate expression of 1/16 scale, all-metal, handcrafted RC tank models. Delivered in a custom-crafted aluminum carrying case, each Mato tank offered by Motion RC contains an extensive list of premium upgrades, including a Flysky 10 channel transmitter, Clark TK50S MFCB, scale T74 metal tracks, wheels, and sprockets, LED lights, sound system, 360-degree turret rotation, Heng Long and Tamiya-compatible IR battle system, cannon barrel recoil, exhaust smoke system, cannon flash, adjustable track tensioners, 5:1 ratio steel gearboxes, adjustable sound effect volume, realistic Vertical Volute Spring Suspension (VVSS) and more!
    Handmade, Not Mass-Produced
    Each Mato tank is individually fabricated and assembled by skilled factory artisans, resulting in a one-of-a-kind replica that any RC armor enthusiast would be proud to own and operate.
    Customized Control
    All Mato tanks offered by Motion RC contain an upgraded 10-channel Flysky transmitter and Clark TK50S Multi-Function Control Board (MFCB).
    Detachable Front Fenders
    The M10 featured front fenders to reduce the amount of dirt and debris in the tracks and turret, and the Mato units are detachable just like the original.
    Custom Carrying Case
    Each Mato tank is delivered in a custom-crafted, durable aluminum case, perfect for secure storage and transportation.
    All Metal Construction
    The M10’s all metal construction faithfully recreates the open turret design of the original vehicle.
    Easy Access
    The upper hull is easily removed for maintenance or adjustment by a thumbscrew, and the power switch and battery charging plug are also conveniently located.
    360° Turret Rotation
    All Mato tanks feature complete, 360 degree turret rotation for scale realism and battlefield convenience.
    Metal Gearboxes
    The 5:1 ratio metal gearboxes provide powerful operation and supreme durability for an unsurpassed scale-realistic model tank experience.
    • 100% handcrafted from metal by skilled factory artisans
    • Factory-applied scale base coat finish ready for graphics and weathering
    • Aluminum carrying case for convenient storage and transportation
    • Advanced Flysky 10-channel 2.4GHz transmitter
    • Clark TK50S Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for recoil, turning control, throttle feel, high speed and low-speed modes, etc.
    • Exhaust smoke effect (on/off)
    • Headlights (on/off)
    • Selectable sound sets with unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound with variable volume
    • Adjustable track tension
    • Track recoil - This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other (compatible with Heng Long and Tamiya IR Battle Systems)
    • Vertical volute spring suspension with metal tracks, sprockets, idlers, and road wheels
    • Mato USA M10 Green Metal 1/16 Scale Tank Destroyer - RTR
    • 2S 7.4v 3000mAh Li-ion battery with Tamiya connector
    • 2S LiPo/Li-ion battery charger
    • Flysky 10-channel 2.4GHz radio transmitter
    • Infrared (IR) battle system receiver
    • Smoke oil
    • Owner’s manuals
    • Custom aluminum carrying case
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 30 Minutes
    Scale 1/16
    Length 450mm / 17.7in
    Width 185mm / 7.3in
    Height 170mm / 6.7in
    Weight 5,500g / 196.4oz
    Body Material Metal
    Chassis Material Metal
    Track Material Metal
    Motors 380 motors x2
    Bearings Ball bearings
    Gearbox Gear Material Metal
    Adjustable Gear Ratio No
    Differential Type N/A
    Suspension Type VVSS
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler Yes
    Turret Rotation 360 degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V (included)
    Required Radio 2.4GHz (included)
    Skill Level Beginner
    Build Time 30 minutes
