Official Mato USA M4A3(75) Sherman Metal 1/16 Scale Battle Tank Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The M4A3(75) Sherman Tank was a key variant of the United States' iconic M4 Sherman, serving as the backbone of Allied armored forces during World War II. Introduced in 1942, the M4A3(75) was equipped with a 75 mm M3 gun, capable of firing high-explosive and armor-piercing rounds, making it effective against both enemy infantry and lightly armored vehicles. Powered by a Ford GAA V8 engine, the M4A3 offered improved reliability and performance compared to earlier models. It featured a welded hull and 51-76 mm of frontal armor, providing moderate protection against German anti-tank weapons. Its standardized VVSS suspension and relatively lightweight design, at approximately 31 tons, allowed for excellent mobility across many types of terrain, providing a crucial advantage for offensive operations.
    The M4A3(75) Sherman excelled in versatility, simplicity, and ease of mass production, with thousands deployed in theaters such as North Africa, Europe, and the Pacific. However, its armor and firepower were often outmatched by German tanks like the Panther and Tiger, necessitating tactics that leveraged superior numbers and coordination. Despite its vulnerabilities, the M4A3(75) played a pivotal role in securing Allied victory thanks to its adaptability and logistical superiority.
    Mato tanks are the ultimate expression of 1/16 scale, all-metal, handcrafted RC tank models. Delivered in a custom-crafted aluminum carrying case, each Mato tank offered by Motion RC contains an extensive list of premium upgrades, including a Flysky 10 channel transmitter, Clark TK50S MFCB, scale T74 metal tracks, wheels, and sprockets, LED lights, sound system, 360-degree turret rotation, Heng Long and Tamiya-compatible IR battle system, cannon barrel recoil, exhaust smoke system, cannon flash, adjustable track tensioners, 5:1 ratio steel gearboxes, adjustable sound effect volume, realistic Vertical Volute Spring Suspension (VVSS) and more!
    Handmade, Not Mass-Produced
    Each Mato tank is individually fabricated and assembled by skilled factory artisans, resulting in a one-of-a-kind replica that any RC tanker will be proud to own and operate.
    Customized Control
    All Mato tanks offered by Motion RC contain an upgraded 10-channel Flysky transmitter and Clark TK50S Multi-Function Control Board (MFCB).
    Metal Gearboxes
    The 5:1 ratio metal gearboxes provide powerful operation and supreme durability for an unsurpassed scale-realistic model tank experience.
    Custom Carrying Case
    Each Mato tank is delivered in a custom-crafted, durable aluminum case, perfect for secure storage and transportation.
    All Metal Construction
    Mato tanks feature meticulously handcrafted metal hulls, chassis, and tracks.
    Unique VIN Number
    Each Mato tank is individually serialized and catalogued at the factory to provide premier customer support and technical assistance.
    360° Turret Rotation
    All Mato tanks feature complete, 360 degree turret rotation for scale realism and battlefield convenience.
    Scale Suspension
    Mato faithfully recreates the VVSS suspension used in the Sherman with stunning scale accuracy.
    • 100% handcrafted from metal by skilled factory artisans
    • Scale, factory-applied finish is ready for graphics and/or weathering
    • Aluminum carrying case for convenient storage and transportation
    • Advanced Flysky 10-channel 2.4GHz transmitter
    • Clark TK50S Multi-Function Control Board (MFCB)
    • Proportional acceleration, steering, turret traverse, and gun elevation/depression
    • Programmable radio settings for recoil, turning control, throttle feel, high speed and low-speed modes, etc.
    • Exhaust smoke effect (on/off)
    • Headlights (on/off)
    • Selectable sound sets with unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound with variable volume
    • Adjustable track tension
    • Track recoil - This shudders the tank briefly rearward to simulate recoil when firing the main cannon
    • Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other (compatible with Heng Long and Tamiya IR Battle Systems)
    • Vertical volute spring suspension with metal tracks, sprockets, idlers, and road wheels
    • Mato USA M4A3(75) Sherman Green Metal 1/16 Scale Battle Tank - RTR
    • 2S 7.4v 3000mAh Li-ion battery with Tamiya connector
    • 2S LiPo/Li-ion battery charger
    • Flysky 10-channel 2.4GHz radio transmitter
    • Infrared (IR) battle system receiver
    • Smoke oil
    • Owner’s manuals
    • Custom aluminum carrying case
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 30 Minutes
    Scale 1/16
    Length 375mm / 14.7in
    Width 162mm / 6.3in
    Height 190mm / 7.5in
    Weight 5,000g / 178.5oz
    Body Material Metal
    Chassis Material Metal
    Track Material Metal
    Motors 380 motors x2
    Bearings Ball bearings
    Gearbox Gear Material Metal
    Adjustable Gear Ratio No
    Differential Type N/A
    Suspension Type VVSS
    Sprocket Metal
    Road Wheels Metal
    Idler Wheel Metal
    Adjustable Idler Yes
    Turret Rotation 360 degrees
    Lights Yes
    Sound Yes
    Exhaust Effect Yes
    IR Battle Ready Yes
    Airsoft BB Launch No
    Track Recoil Yes
    Cannon Barrel Recoil Yes
    Required Battery 2S 7.4V (included)
    Required Radio 2.4GHz (included)
    Skill Level Beginner
    Build Time 30 minutes
  • SoCalBobS
    • 2761
    • Southern California
    Very good model. I decorated mine as the "Kelly's Heroes" tank.
Name:	Kellys Heroes 23.jpg
    • DavidN
      • May 2021
      • 3204
      • Los Angeles, CA
      A member in the SoCal RC Tank Club club gave me just the the upper hull of this Mato Sherman a few months ago. Little by little, I gathered parts to finally have it in running/battling condition. I have the HL 7.1 board inside. Barrel recoil and elevation features are functional. It will be sent to the paint shop later this week.
      Click image for larger version  Name:	IMG_7709.jpg Views:	0 Size:	146.7 KB ID:	448530
      • DavidN
        • May 2021
        • 3204
        • Los Angeles, CA
        Considered it done for IR battle. ​
ID:	448927 Click image for larger version
ID:	448928 Click image for larger version
ID:	448929 Click image for larger version
ID:	448930 Click image for larger version
ID:	448931 Click image for larger version
        • SoCalBobS
          • 2761
          Congratulations! One thing: the track link ears can get bent, which can then cause a jam or detrack. I bought a set of extra links from MatoMart to replace any bad ones.
          • rb67mustang
            • May 2026
            • 290
            • People's Republic of Rhode Island
            Bob, I love the work you've done to recreate Oddballs M4. Kelly's Heroes is one of my all time favorite WW-II movies even though the plot is fiction. The only question is where did you get the loud speaker for your build???
            • rb67mustang
              • May 2026
              • 290
              Great work, DavidN!!! I love it.
              • rb67mustang
                • May 2026
                • 290
                DavidN, where did you get the decals for this build?
                Thanks, Roger
                • SoCalBobS
                  • 2761
                  It was pat of a 3D file I had a friend make. It included the lantern and milk can from the movie. I don't recall the source of the files, but check Cult3D, Thingiverseor CGTrader. That's where I find most of my stuff. I made a bracket from brass stock to mount it to the turret.
                  • rb67mustang
                    • May 2026
                    • 290
                    Thanks, Bob!
                    • DavidN
                      • May 2021
                      • 3204
                      • Los Angeles, CA
                      Thanks, Roger
                      They were from the NF Model EZ8 tank version 5. I bought the version 2 and I asked the Toucan rep to sell just the decal for the version 5.
                      • rb67mustang
                        • May 2026
                        • 290
                        Thanks, David, I'll see if Toucan sells just decals.
                        • SoCalBobS
                          • 2761
                          rb, I've been playing with ChatGPT (flooding the forum, actually). Here's one:
                          Click image for larger version  Name:	0d70fa35-f65e-4257-b635-1996b478fd94.png Views:	0 Size:	2.11 MB ID:	450330
                          By the way, that shade of green is from the movie. They used Yugoslavian Shermans for it.
