Looking for my next Sherman, need advice
  • Matchstick101
    • Feb 2025
    • 3
    So right now I'm looking into getting another Sherman to go along with my HL M4A3(105). I'm torn between the Mato M4A3(75) and Taigen M4A3(76). I like the fact the mato comes with a clark board and that it's full metal. On the other hand the taigen is almost half the price.
  • keilau
    • Mar 2021
    • 1844
    • Windy City
    Since you are at this budget range, the first choice is Tamiya M51 Super Sherman 1/16 RC tank. It is in kit form only and is discontinued. It may be difficult to find and expensive. The Sherman is a medium tank. The chassis is small in 1/16 scale. Tamiya is the only RC that uses 540 motors.
    Please prove that you are Human before accessing this website
ID:	420374 Click image for larger version
    • keilau
      • Mar 2021
      • 1844
      • Windy City
      If the M51 SuperSherman is impossible to find, Tamiya did offer an old kit last year as a second choice.
      Originally posted by tamiyausa.com
      To commemorate the 50th anniversary of the 1/16 R/C Sherman kit in 2024, Tamiya is delighted to announce the reproduction of Item 56014 1/16 R/C M4 Sherman 105mm Howitzer Full-Option Kit.
      The M4 Sherman was a mainstay of the Allied WWII war effort and was manufactured in several different variants including the 105mm howitzer depicted by this highly realistic R/C model assembly kit. Along with the accurate form of the vehicle, this model features moving suspension, realistic sounds and even lights for a truly all-encompassing scale armor experience.​
      • keilau
        • Mar 2021
        • 1844
        • Windy City
        When buying a Tamiya 1/16 scale RC tank, usually, the radio controller is NOT included.
        https://www.ebay.com/itm/13504437360...Bk9SR6ror-WlZQ
        • keilau
          • Mar 2021
          • 1844
          • Windy City
          I upgraded my Heng Long Sherman with parts from different sources. Total cost is about the same as the Torro Sherman.
          Hello, RC Tankers! Please post photos of your RC tank in this thread. Share both your stock tanks and your customized creations, too! If you've personalized your tank, please also share what modifications you have done, so the rest of us can learn. I look forward to taking inspiration from your RC tanks! bbkth3.jpg
          • cleong
            • Feb 2024
            • 34
            Tamiya only uses 540 motors on their specialized diiferential gearboxes where one motor provides drive and the other provides turning. Off the top of my head, that's the Leopard 2, Type 10 and Abrams - for all the rest - they use 380 motors.
            • keilau
              • Mar 2021
              • 1844
              • Windy City
              I believe you are correct. I was misled by the product posting of the M4 Sherman at MotionRC.com
              Originally posted by MotionRC.com
              Features:
              • Two Type 540 motors that can operate together or individually to produce forward/reverse running and pivot turning
              • Metal torsion bars and suspension arms combine with the wide tracks to smoothly absorb bumps and dips in the terrain and provide high maneuverability
              • Realistic engine sounds accompany the tank as it starts up, drives, and stops to idle
              • Hull-mounted main gun can be elevated, depressed, and swung to the left and right
              https://www.motionrc.com/products/tamiya-m4-sherman-105mm-howitzer-full-option-1-16-scale-medium-tank-kit-tam56014?variant=44644609491129&country=US&currenc y=USD&utm_medium=product_sync&utm_source=google&ut m_content=sag_organic&utm_campaign=sag_organic&srs ltid=AfmBOorwt2Lth4yHSsJzM2c2zFhNYxgcQc6Ml-aBUt4U633pGCy_UFw8vo4
              • DavidN
                • May 2021
                • 3203
                • Los Angeles, CA
                If you like metal, have the $, and intend to IR battle in clubs, go with the Mato. If you have less $ and don't intend to IR battle in clubs, go with Taigen/Torro. If you have little $ and don't mind plastic, buy the HL and upgrade with Richard Johnson's conversion kit....It is so durable and you will hardly ever de-track.
                Click image for larger version  Name:	IMG_6288.jpg Views:	0 Size:	207.5 KB ID:	420421
                • Matchstick101
                  • Feb 2025
                  • 3
                  I am looking into getting into a club. in fact i don't live to far from the tank museum where the LA tank club plays. Been wanting to swing by and see everything but back to the matter at hand. I've been leaning to the Mato as it looks like it would be an easy way to get a ir ready tank and as much as I would love to own a Tamiya tank. I just don't have the time to build something like that. I mean, weathering and detailing my HL Sherman was one thing but building from the ground up would take me forever.
                  • DavidN
                    • May 2021
                    • 3203
                    • Los Angeles, CA
                    Have you installed the LegoDEI IR battle unit into your other Sherman yet? You can start battle with that one first before moving into the Clark's board type.
                    • Matchstick101
                      • Feb 2025
                      • 3
                      I didn't know the LegoDEI unit could work stock with a HL 7.0 board.... I wouldn't mind taking "Buffalo" out to battle
                      • SoCalBobS
                        • 2754
                        • Southern California
                        LegoDEI sells two versions, one that works on Heng Long, one that works on Clark, etc. They're not cross compatible, so order the correct one for your use.
