How can I make my Abrams faster?
  • RichJohnson
    • 1276
    You trying to build a submarine?
    younwould have to seal every opening in the hull. Water tight and any shaft penetration would need very thick grease.
    Doing that it would probably float.
    • Rubicon99
      • 3316
      Originally posted by Woohoo\o/
      Under normal circumstances I drive this tank at 70% power. But when filming for cinematics I run it at 100% power because it just looks better when 100 power is slowed down. I know it sounds silly and probably doesn’t make any sense but after much trial and error it just looks better in my humble opinion. And yes I’m learning a lot as I go. The Abrams isn’t my ir battle tank. That’s for my merkava which runs all stock except red 390 motors.
      What can I do to make my tank waterproof?
      Water is not a big problem for anything except the MFU, battery and possibly the speaker. Seal them in some sort of waterproof "container" and you should be relatively fine. I have seen this done with something as simple as plastic bags. The motors will dry out pretty quickly and unless it's salt water you are driving in there really should be no worries about rust even in the gearboxes as long as they are well greased.
      • Woohoo\o/
        • Feb 2020
        • 186
        • Cape coral Florida
        Thanks guys and no lol not a submarine. I just enjoy the looks of tanks doing what tanks do and plenty of that involves water. I will never completely submerge my tanks. But if you watched my video I do go into shallow puddles.
