I just installed a Lego DEI in a HL Abrams pro edition installed as video shows but I’d does not light up on start up or when registering hits the tank reacts as it should but no lights this receiver is a replacement for another one ordered but was faulty .Is there something I have missed ?
Lego IR
Tags: None
The first one sent was the new style tried it on my orders and didn’t work the one they sent as a replacement is the older style with just the 5 pins exposed as I ran some tests today it doesn’t seem to pick up any thing lights on/lights off and will not register hits at any range Could my 7.0 board be bad ?Comment
The first receiver sent was new style and it was doa no function at all the replace ment is the older style and it will function ok my other HL tanksComment
Make sure you have the power for the LEDs (one plug two lines) plugged into the correct slot on the 7.0 and that it is not plugged in reverse + - vs - +. These two are the most common mistakes when installing the Lego receivers that cause the effect you are having.I just installed a Lego DEI in a HL Abrams pro edition installed as video shows but I’d does not light up on start up or when registering hits the tank reacts as it should but no lights this receiver is a replacement for another one ordered but was faulty .Is there something I have missed ?Comment
I checked the two wire single plug it was in correctly ,so I set to work with the volt meter, the center wire on the male plug of the ir receiver plug was giving a intermittent signal so I totally replaced that end and it seems to be working like it should . I am still kicking around the idea of replacing the 7.0 with a 7.1 and adding a few turret mounted trinkets . Thanks for all the help and suggestions. (P.S. I hate wiring gremlins )Comment
Unless you are converting over to servo recoil and/or servo elevation, there is no real benefit to switching to a 7.1. Other reason may be if you want to use the trim channel on the 7.1 to control a CROWS or commander's site movement.Comment
