What did you do with the HL 7.1 upgrade
  • bdarienk
    • Nov 2025
    • 7
    If you upgraded to the henglong 7.1 controller, what did you do with it? Did you find it worth doing?
  • keilau
    • Mar 2021
    • 1844
    • Windy City
    Spend more money on a servo barrel unit and servo elevation unit. It worths every penny because it is your hobby for fun. If you do not plan to implement the servo function, the HL TK70 is a much better deal.
    • tank_me
      • Feb 2022
      • 1197
      Only reason you really want to do it is if you need servo connections for external electronic speed controllers (ESC) or the other servo functions which if you get the 7.1 transmitter adds an extra control slider. The extra slider can be used for a bunch of things like controlling a motor via ESC or servo.
      If you don't need any of that stuff or know what I'm talking about then it won't give you anything you don't already have.
      • SoCalBobS
        • 2754
        • Southern California
        The most common need for a 7.1 controller is for servo operated gun elevation, the second is for servo operated main gun recoil. Many new tanks from Tongde, Coolbank, Mato and others use servo elevation and recoil, so if you plan to convert them to Heng Long electronics, you'll need the 7.1 board. As Tank-Me states, if you don't use those functions, 7.0 is fine. Other than the extra functions, they are interchangeable - &.0 transmitters can operate both 7.0 and 7.1 boards, and vice versa.
        • MrChef
          • Jan 2023
          • 510
          • New York, Not the city
          By "7.1 controller" do you mean the board or as Heng Long calls it an MFU inside the tank?
          The 7.1 board provides what everyone has already mentioned.
          The "7.1 Controller" in your hands with the joysticks and buttons provides the ability to control the extra options that tankme mentions.
          BUT, the standard Heng Long TK7.0 controller or TX can control the Servo cannon barrel recoil and elevation. It doesn't have the slider control as tankme mentions for controlling added features of the 7.1 board.
          I use the TK7.1 board/MFU with the TK7.0 controller to do this-
          • bdarienk
            • Nov 2025
            • 7
            Thanks for help.
            • DavidN
              • May 2021
              • 3203
              • Los Angeles, CA
              I have just bought my very first 7.1 HL controller (with the slider). I would like to maximize the slider purpose. Can anyone lmk what it is used for and which port is connected into the 7.1 board for that feature? I hooked up my servo and nothing moved as I slid it side to side.
              On the controller, there are some functions: G+A, G+S, K+2(up), and K+2(down). What functions do they perform on?
              I also have questions on the 7.0 and 7.1 board: CN5, CN13, CN14, CN17, CH3, CH4, and L10. Has anyone use any of these ports and for what feature and purpose?
              I will do my own search on these. However, if you know, please share! Thank you!
              • DavidN
                • May 2021
                • 3203
                • Los Angeles, CA
                Found an old post and hooked the servo on to CH5. The slider works now, heheh!
