Otto's Tiger.
  • Chris curran
    • Aug 2020
    • 215
    Otto's Tiger.
ID:	441808 Ok, After finishing my Odd Ball sherman, I Decided to make Otto's T-34 Tiger. I used a HL plastic hull and turret as the sacrificial lamb for this. Ok, That being said, I started with the T-34 chassis, then Narrowed the tiger hull by 3/8" per side, then re attached the side skirts. I also moved the turret forward by an inch. I'm liking the way it looks so far. I have more to do, but most of the Heavy lifting's done. Now on to the fun bits.
    Click image for larger version  Name:	20251228_134805_HDR.jpg Views:	35 Size:	97.9 KB ID:	441782 Click image for larger version  Name:	20251228_135955_HDR.jpg Views:	29 Size:	134.9 KB ID:	441784 Click image for larger version  Name:	20251229_003858_HDR.jpg Views:	29 Size:	137.3 KB ID:	441785 Click image for larger version  Name:	20251229_003944_HDR.jpg Views:	29 Size:	131.3 KB ID:	441786 Click image for larger version  Name:	20251229_003956_HDR.jpg Views:	30 Size:	118.4 KB ID:	441787 Click image for larger version  Name:	20251229_004038_HDR.jpg Views:	29 Size:	100.8 KB ID:	441788 Click image for larger version  Name:	20251229_004051_HDR.jpg Views:	29 Size:	92.6 KB ID:	441789
    Last edited by Chris curran; Dec 29, 2025, 08:56 PM. Reason: I had to enlarge one picture.
  • Meter Rat
    • 504
    • Argyll and Bute, Scotland
    Looking good Chris. Always wanted to see someone do a model of Otto’s tank. Everyone concentrates of Oddball’s.
    • Chris curran
      • Aug 2020
      • 215
      I have a guy making me the Otto Figure, So, this had to be done.
      • Chris curran
        • Aug 2020
        • 215
        Ok, Here are some more pics. I extended the rear end bu 1/2 inch, and I made some brackets for the front, and canabalized the Bracket for the rear deck.
ID:	441837 Click image for larger version
ID:	441838 Click image for larger version
ID:	441839 Click image for larger version
ID:	441840 Click image for larger version
ID:	441841 Click image for larger version
ID:	441842 Click image for larger version
        • Chris curran
          • Aug 2020
          • 215
          Ok. I added the Zimmerit and the wheel covers. The wheel covers came from the same Donor Tiger I took plastic parts from
ID:	442224 Click image for larger version
ID:	442225 Click image for larger version
ID:	442226 Click image for larger version
ID:	442227 Click image for larger version
          • Chris curran
            • Aug 2020
            • 215
ID:	442901 Click image for larger version
ID:	442902 Click image for larger version
ID:	442903 Alright, Here are some more pics of the T-34 Tiger. In the Home streatch. Click image for larger version
ID:	442897 Click image for larger version
ID:	442898 Click image for larger version
ID:	442899 Click image for larger version
            • MrChef
              • Jan 2023
              • 501
              • New York, Not the city
              This is just so cool Chris! Agreed with Mr. Rat, I've never seen the Tiger done and you sure did it. Nice one sir! Can't wait to see it with the Otto figure as well next to your Oddball model.
              • SoCalBobS
                • 2716
                • Southern California
                Excellent! I have an Oddball Sherman, and every time someone sees it they say "I should" make the Tiger to accompany it. You've done it!
Name:	Kellys Heroes 10.jpg
                • Chris curran
                  • Aug 2020
                  • 215
                  Thanks Bob. It takes a Special person to tackle this projact and i'm, um, Special.....After I made my Oddball Sherman, I really wanted the foil. Well, the fella in England who made my Sherman crewMakes Otto, Kelly, and Big Joe. So I'm having them made for me. Another reason I took on this project.
                  • Chris curran
                    • Aug 2020
                    • 215
                    Thanks Chef. It was a lot of work, but worth the effort. I'm gonna have to put them both together when this one's done. I'm adding some more pics now.
                    • Chris curran
                      • Aug 2020
                      • 215
                      Ok we're almost done. I replaced the wood spacer in the rear with a plastic piece, then adder the dirt and weathering.
ID:	443152 Click image for larger version
ID:	443153 Click image for larger version
ID:	443154 Click image for larger version
ID:	443155 Click image for larger version
                      • SoCalBobS
                        • 2716
                        That's the right color from the movie! Bravo.
                        • Chris curran
                          • Aug 2020
                          • 215
                          Thanks Bob . I'm trying to get it as close to Movie correct as possible. I used the Soviet colors that the Yugo's used. I even have netting and foliage to add to it.
                          • Meter Rat
                            • 504
                            Chris. You should really do a second one, with a big pink blob on the rear. This is just a great build.
                            • Chris curran
                              • Aug 2020
                              • 215
                              Thank you meter. Ya know, I was thinking that but decided not to. So, I stuck with the hero tank instead. Plus, I have an Otto figure coming.
                              • Chris curran
                                • Aug 2020
                                • 215
                                Ok. It's finally finished. Here it is.
ID:	443792 Click image for larger version
ID:	443793 Click image for larger version
ID:	443794 Click image for larger version
ID:	443795 Click image for larger version
ID:	443796 Click image for larger version
