I have a Taigen Panzer IV here that is configured for Airsoft, how difficult is it to convert this to IR ? Tried searching, but found little info on this. thanks
Converting Taigen Panzer IV from Airsoft to IR. How difficult ?
There are a couple of ways. Do you want to remove the gun or just make it IR battle compatible? If you want to remove the gun use Rich's gun breach. Drops right in where there gun holds the barrel. http://www.richardsjohnson.net/id28.html acroll down till you find recoil unit. I use them in my tanks. Even if you don't use the recoil they work with the stock Heng Long elevation servo.
All the IR receivers are from Lego DEI and are drop in with stock Heng Long Just make sure you buy the cable and buy only the V2 receiver. V3 are too sensitive.
.png)
