This is getting kind of nuts. I have a Mato Stug III and M36 Jackson I have not used since before the New Year.
I charged them up and was running them around the house and noticed ranging issues with these, meaning they didn't register hits on one another unless they were within a few feet of one another. This was not the case when I used this in December.
For the M36 Jackson, I was thinking since it was fairly easy to swap out the IR emitter on the M4 Sherman I have, this would be an equally simple task. Wrong. I started that last night and found that disassembly of that proved to be more complex than the M4 Sherman, and not only could I not get the IR emitter and flash emitter removed the cannon barrel, they also had ended up splicing the positive wires of those two emitters together prior to shoving them down the cannon barrel ( not that big of a deal but I find it kind of odd ). I am thinking once I get the cannon barrel out using either a heat gun to melt the adhesive or pouring some rubbing alcohol down there will loosen things up.
As a side note, after starting, and than stopping and putting it back together last night I noticed that the IR emitter seemed to have some kind of haze on it so put some rubbing alcohol on a Q-Tip and was able to get the haze removed and the emitter seemed to function better last night but when I just tried it now it was not so it definitely needs to be replaced.
My question(s) on this is, how often have people noticed IR emitters failing ? This is the third tank I've had this happen on from them in the space of a year and these things do not get run that often. Second question is, has anyone here dissembled a Mato M36 Jackson ?
Now, for the Stug III, this had no issues the last time I used this in December ( except for arriving to me with the IR emitter painted over by Mato ), but this one also had ranging issues. Hits on opposing tanks only registered when the other tank was a few feet away whereas in December hits were registered from up to 30-40 feet away. When I looked at the emitter on this tank with my iPhone camera, it pretty much appeared to be in an " always on " state, meaning the purple light from the emitter was apparent as soon as the tank was turned on and did not change in intensity when the cannon was fired, although hits on opposing tanks were only registered when the cannon was fired. Does anyone have any idea what would cause the emitter to appear to be in an " always on " state ? I am still learning about this stuff so I have no clue if thats some kind of failure in the emitter, a possible issue with the clark board, or is just the nature of some of these emitters.
Cross posted this on RCtankwarfare also, and will be checking both sites for replies so no need to reply to the threads in both locations.
ETA: Gets more weird. I tried using both a Heng Long tank and a Torro tank as the target tanks for these two Mato tanks. Hits on the HL tank were registered when the Mato tanks were up to 30 feet away. Hits on the Torro tank were one registered when the Mato tanks were within 3 feet, the same as when both Mato tanks were firing on each other. I guess it's possible that the receiver on the HL tanks is powerful enough to detect weak IR emissions and the receivers on the Torro and Mato tanks are unable to do so.
