Large Hatch (Hercules) M4 Tanks
  • SoCalBobS
    David, thanks for the info. Let us know about this:
    How does the steering with the NF board compare to HL? HL turns smoother than TD.
    How does the "shake when hit" compare to the HL? HL is milder than TD.
    Does it have adjustable track tension?
    How does one change out the battery?
    Also when you run it in battle, let us know if it's vulnerable to detracking. Rich's kit seems to be "bulletproof". It has NEVER detracked in my use, Rich's either I'm told.
    Thanks!
  • DavidN
    No! I keep the same board. I like its controller too. Its board is almost 99% similar to HL 7.0 board. It can be used with the LegoDEI receiver. So it can battle with HL and Tamiya battle systems. It also come with its two unique engine sounds: Continental and Ford. The drive is quite smooth. The teeth of the sprockets fit well with the metal track links. I will finish it by Saturday and battle it on Sunday to see how it fights.
  • RichJohnson
    Are you converting to a HL 7.1 MFU?
    what so you think about the rest of the tank model?
  • DavidN
    Modifying the barrel recoil unit; switching the IR emitter; adding barrel flash; adding MG LED at front of turret.
  • 1meandad
    Mine arrived yesterday as well
  • DavidN
    My metal EZ8 arrived today...
ID:	448870 Click image for larger version
  • DavidN
    Originally posted by 1meandad
    Link for their ordering site?
  • 1meandad
  • DavidN
    started a topic Large Hatch (Hercules) M4 Tanks
    Here are the 6 versions of the M4 tanks produced by the company names Large Hatch. Two of our club's members got the version 1 and 4. I have just ordered the version # 2. It won't be here till 5/15//26. I will look at the other 2 tomorrow at our event.
ID:	448040 Click image for larger version
ID:	448041 Click image for larger version
ID:	448042 Click image for larger version
ID:	448038 Click image for larger version
ID:	448036 Click image for larger version
