David, thanks for the info. Let us know about this:
How does the steering with the NF board compare to HL? HL turns smoother than TD.
How does the "shake when hit" compare to the HL? HL is milder than TD.
Does it have adjustable track tension?
How does one change out the battery?
Also when you run it in battle, let us know if it's vulnerable to detracking. Rich's kit seems to be "bulletproof". It has NEVER detracked in my use, Rich's either I'm told.
Thanks!
Large Hatch (Hercules) M4 Tanks
No! I keep the same board. I like its controller too. Its board is almost 99% similar to HL 7.0 board. It can be used with the LegoDEI receiver. So it can battle with HL and Tamiya battle systems. It also come with its two unique engine sounds: Continental and Ford. The drive is quite smooth. The teeth of the sprockets fit well with the metal track links. I will finish it by Saturday and battle it on Sunday to see how it fights.
Are you converting to a HL 7.1 MFU?
what so you think about the rest of the tank model?Leave a comment:
Tags: None
