Heng long open fire smoking michine gun
  • Heng long open fire smoking michine gun
    Just information on which 2 ports to plug the heng long smoking michine gut into.
    1. The led wire black plug goes to led port 5 with the wire on the negative post.
    2. The wire with the white connector goes to cn 17.
    On the circuit board that came with the unit there is a small phillips screw head to turn smoke up or down.
    David
    Do you have a picture of the smoking machine gun? I’ve not seen that option before, only the machine gun with the led light or main barrel smoke unit.
      Evey time I try to post a picture all I get is something went wrong. You tube has videos of the gun.
        A link to the YouTube video?
          Link to youtube smoking michine gun
          Source: Facebook https://share.google/SgoMebB0wO7CmqBja
            You haven’t given us very much to go on. You may need to put a link across CN6 to get it to work.
              All I had to do was plug the white plug into cn 17 and the black plug into led 5 with the 1 wire to ground. I did nothing the cn6.
              attached the tubing from blower to the inlet on the smoke unit then put a tube from the out let on the smoke unit to the michine gun and mine worked great.
                Very interesting!!! How much does that option cost??? And what board is required for that option???
                  I'm using mine on a heng long 7.0 cost me $35.00 from heng long.
