Switch location
  • PanzerLoco
    • May 2024
    • 109
    Switch location
    I don’t understand the trend among so many RC tank manufacturers of placing the power switch inside the driver’s hatch.
    I miss the older generation of RC tanks, with the power switch underneath the hull.
    What’s the idea behind this? Is opening the driver’s hatch just to turn the power on supposed to be part of the thrill?!
    Adding a driver figure brings so much life to an RC model, and having the power switch right there can really get in the way of that.
    Cheers, Panzer Loco!!
Name:	T34 driver.jpg
  • tank_me
    • Feb 2022
    • 1199
    I don't do figures on my tanks as painting is the part of my build I only tolerate. Painting figures is definitely a no go for me. The only vehicles I have that have figures are wheeled ones where it looks strange not having a driver.
    I like having it on top of the tank so I don't have to pick the tank up or feel around the bottom to find the switch. Also if you run in any water, having the switch that low isn't great. I would say that there is also a greater chance of something hitting it (although slim I know) while driving. For some tanks I have also filled the lower with resin for a little extra weight and it ends up being another hole to plug. Lots of disadvantages for the way I use my tanks. I don't necessarily put it under a crew hatch. I will also put them under engine hatches, etc. I battle my tanks so most of the time I have a battle system in one of the turret hatches so it doesn't bother me at all.
    • SoCalBobS
      • 2756
      • Southern California
      To chime in; the Heng Long on/off switch is not current bearing, and I've found that a momentary switch will activate it. On some tanks I battle roughly, I've installed them in obscure places, not readily visible, but easily accessible. This one at the rear of a T-34 actually shows more than some others.
      Click image for larger version  Name:	IMG_3180.jpg Views:	0 Size:	28.8 KB ID:	453731
      Please disregard the empty slots. Those parts are somewhere on battlefields someplace in Southern California! I meant it when I said roughly.
      • tank_me
        • Feb 2022
        • 1199
        The older 5.3 and RX-18 based tanks where the switch was on the bottom were current carrying as there is no slot on those boards for a dedicated switch circuit. Since Clark boards were designed at a time when those boards were common, a lot of Clark installations use a current carrying switch. Taigen/Torro also uses a current carrying switch. I agree that the HL 6.x/7.x series of boards do not carry current on the switch. Even if the switch doesn't carry current, still not a good idea to get them wet as they will internally corrode leading to failure.
        • SoCalBobS
          • 2756
          Good clarification. It's only the HL 6 and 7 series that you can get away with this!
