For a long time, I’ve been waiting for one of the RC Tank Manufacturers to offer one of the early Pattons like the M46 or M47. I finally got tired of waiting and decided to build my own, selecting an M46 for the project. The M26 Pershing and M46 Patton are very similar, sharing the same turret and front-half of the hull. The US Army’s first M46 Pattons were actually converted from Pershings. So, I purchased a Heng Long M26 Pershing from MRC and got to work. Below are photos of the M26 as it originally appeared:
To make the conversion, there are essentially three things I have to accomplish:
I decided that the first order of business should be to relocate the Drive Sprockets upward and slightly to the rear. After a bit of measuring, I determined that the Sprockets should be moved up to a new center-line located 27mm above the bottom of the hull to put the Sprocket in-line with the Return Rollers.
After removing the original Drive Box, I cut a slot in the hull to allow the drive-sprocket to be moved upward, then sealed the original hole with a patch made from EVERGREEN plastic sheeting, and tidied it up with BONDO GLAZING AND SPOT PUTTY.
It was necessary to replace the original drive unit with a new Heng Long Middle/Low-Long Shaft Steel Gear Drive Box (HL G6020-008) to allow the Drive Box to be raised without it striking the underside of the engine-deck. I 3-D Printed two Wedges that supported the rear of the Drive Box at the correct height, leaving the front of the box still resting on the hull floor so it wouldn’t come in contact with the underside of the engine deck. I glued them in place and then screwed the Drive Box in on top of them. The Drive Box fit under the new Engine Deck . . . barely.
With the new power-unit installed, there was no longer room for the exhaust unit to be installed behind it, so I re-located it forward and installed it in two pieces on either side of the battery box connected with a piece of brass-tubing.
From the Exhaust Smoke Box, a soft Plastic Tube carries the exhaust to a Box mounted to the underside of the Engine Deck where the exhaust is split in opposing directions and sent to the Silencers (Mufflers) on the two back fenders.
After cutting off the M26 Exhaust Port, I printed a new rear panel to match the M46 and shaped it like a wedge to correct the rearward slope of the original panel, bringing the new panel to the vertical. Then it was a matter of using sheet plastic to fabricate the M46’s distinctive shape.
Shifting to the Upper Hull, I set about removing the Side-Skirts. I accomplished this using an Acrylic Sheet-Cutter and a Utility Knife. Although the real M46s were delivered with Side-Skirts installed, the crews quickly got rid of them as they made Track and Return-Roller maintenance harder and offered little in the way of protection. Besides, the tank looks much better without them.
Next, I removed the rear fenders. I would hang onto them for modification and re-installation later.
And then I cut out the existing engine deck.
The new Engine Deck was Designed in Tinkercad in three pieces due to size limitations of the build-plate on my 3D Printer.
It took a few tries, but I eventually got the panels to match up with the new rear panel with a good fit. Designing them in TinkerCad was a bit tedious, but do-able. I then added new rear-fender panels upon which to mount the distinctive exhaust mufflers, and re-attached the original rear fenders (slightly modified).
I 3D Printed the exhausts open-topped to make it easy to route the plastic tubes carrying the exhaust. The 3D Printed Covers hid the tubing nicely.
When the tubing was all in place, I gave it a test-run. It worked, but the exhaust-smoke has a tendency to follow the curve of the fender instead of billowing like a real exhaust. Haven’t quite figured out how to correct that yet. Perhaps I can devise some kind of diffuser that I can insert into the exhaust pipes. I welcome any suggestions.
Here's a good place to pause. I'll pick it up again in a few days with the detail-work on the hull. Then, on to the turret.
- Move the Drive Sprocket up higher even with the Return Rollers
- Re-Work the Engine Deck and Exhausts
- Re-Work the Main Gun by re-locating the Gun-Mount, replacing the Muzzle Brake and adding a Bore Evacuator.
