Version Info: This truck is a KIT. Assembly is required. Minimum 4+ channel radio system, ESC, battery, charger and servo will need to be purchased separately.
This is a special edition of the R/C Mercedes Benz Arocs, the super-stylish 3-axle truck with distinctive bucket tooth grille. It is a great option for those without the time or confidence to apply a paint job to their kit, as the cab, H, K, and M parts of the kit are pre-painted in Light Gun Metal (Tamiya Color TS-42), and given a urethane coating for a beautiful finish, and protection from damage.
Tamiya is world-renowned for producing industry-leading RC scale tractor trucks for generations. The Tamiya Mercedes Benz Arocs 3363 6x4 Hauler is powered by a 540 motor and 3-speed transmission, its durable drivetrain spins both rear dually axles supported on a realistic leaf spring and shock suspension. The Mercedes Benz Arocs 3363 6x4 Hauler's metal C-Channel ladder frame keeps the power to the pavement when hauling optional accessories. Your Tamiya truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
Visit the product page here. ![]() |
540-Sized Motor and 3-Speed Transmission The 540-sized brushed motor applies power through a selectable 3-speed transmission to drive dual rear axles. |
| Exceptional Scale Detail Scale details surround this truck for exceptional realism. |
Dual Rear Axles Each axle is supported with leaf spring and shocks. |
| Optional Light and Sound Add your own light and sound package with the separately-sold Multi-Function Control Unit MFC-01 or MFC-03. |
1/14 Scale This truck comes in an impressive 1/14 scale. Coming in at nearly 2 feet in length, it has an ideal on-road presence while being convenient to transport. |
| Add Your Own Electronics and Drive! Once you add your preferred electronics you're ready for those on-road adventures. |
- Exceptional scale detail and realism brings this truck to life on every level
- Interior features such as seat and dashboard are depicted
- 3-axle chassis utilizes ladder frame with aluminum side channels and resin cross members. Realistic drivetrain has a front mounted motor powering twin rear axle
- 3-speed transmission can be controlled via 4ch R/C transmitter
- Highly realistic suspension employs metal leaf spring dampers and friction dampers
- Coupler is included to enable connection with any currently available Tamiya 1/14 scale trailer
- Compatible with tractor truck option parts (TROP)
- Use with Multi-Function Control Unit MFC-03 or MFC-01 for realistic lights and sounds
