Official Cross 1/10 Scale FR4 Demon 4x4 4WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    FR4 Demon 4x4 Blue 1/10 Scale 4WD Truck - RTR from Cross RC - CZRFR4RTRB
    FR4 Demon 4x4 Gunmetal 1/10 Scale 4WD Truck - RTR from Cross RC - CZRFR4RTRG
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter and either LiPo, LiHV or NiMH batteries, purchased separately (see Requires below for details).
    This Cross RC FR4 Demon 4x4 is a 1/10 scale truck that is fully assembled and includes a 2.4GHz transmitter. Simply add 4 AA batteries to your transmitter and your choice of battery for the truck (see Requires below) and you're ready to explore endless outdoor canvases! Your Cross RC car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    4WD System
    The 4WD system comes with optimized motor and gearbox position and CVD metal driveshafts.
    High-Torque Power System
    Features a Cross RC 35T High-Torque brushed motor and Precision FWD/REV ESC with T connector manufactured by Hobbywing.
    Optimized Handling
    With the optimized transmission and transfer case w/metal gears and 50.5:1 reduction ratio, take your FR4 Demon anywhere you want to go with confidence.
    RTR, Just Add Batteries
    Your FR4 Demon comes with a 2.4GHz transmitter. Simply add 4 AA batteries to the transmitter and your choice of battery for the truck (see Requires below) your adventure awaits!
    FEATURES:
    • Fully Assembled 1/10 Scale R/C Model with 2.4GHz Radio System
    • 4WD system with optimized motor and gearbox position and CVD metal driveshafts
    • Chassis side guards included
    • Precision aluminium alloy coil-over shock absorbers with threaded adjusters
    • Optimized transmission and transfer case w/metal gears and 50.5:1 reduction ratio
    • Cross RC 35T High-Torque brushed motor
    • Highly-detailed 1/10 scale painted, trimmed, and mounted polycarbonate body
    • LED headlights and marker lamps
    • Precision G2 Axles with durable nylon housing and metal gear internal gears
    • Inner Fender Liners
    • Hi-Torque Precision Steering Servo
    • 115 x 45 High Performance All-Terrian Tires with 1.9″ Wheels
    • Precision FWD/REV ESC with T connector manufactured by Hobbywing
    • C-type Steel Ladder Chassis design
    • Heavy-Duty metal 4-Link Rods
    INCLUDES:
    • Cross RC FR4 Demon 4x4 Blue 1/10 Scale 4WD Truck - RTR
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 11 AND UP
    SKILL LEVEL : BEGINNER
    BUILD TIME : NONE
    Model Scale 1/10
    Length 660.4mm / 26in
    Width 203.2mm / 8in
    Height 612.4mm / 16in
    Weight (No Battery) 6123.4g / 215.9oz
    Wheelbase N/A
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 115mm x 45mm
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 50.5:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control Precision FWD/REV ESC
    Motor 35T High-Torque Brushed Motor
    Battery 4x AA alkaline for transmitter and either NiMH/LiHV or LiPo battery (required)
    Servos N/A
    Radio 2.4GHz transmitter
    Lights Yes
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Outdoors, smooth to rugged surfaces
