Official Kyosho 1/10 Scale Fazer Mk2 Rage 2.0 4WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Fazer Mk2 Rage 2.0 Red 1/10 Scale 4WD Truck - RTR from Kyosho - KYO34411T1B
    Fazer Mk2 Rage 2.0 Green 1/10 Scale 4WD Truck - RTR from Kyosho - KYO34411T2B
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.2V 1800mAh NiMH battery and a battery charger, purchased separately (see Requires below for details).
    Kyosho ‘maintains the RAGE’ with a huge evolutionary leap forward in the SUV racing truck category, with the 2nd generation RAGE 2.0. While keeping the cost-performance advantages of the original, the RAGE 2.0 has been redesigned with this full-model makeover incorporating the latest racing tech. Core strength has been increased through new materials and ribbing with stiffeners on front and rear, while the simplified chassis design uses less parts to deliver maintenance efficiency and chassis rigidity. In addition, the symmetrical chassis design provides excellent front-rear balance through the suspension and tires with consistent driveability, irrespective of power source.
    Featuring a slipper clutch, front & rear gear differentials, oil shocks and full ball bearing specs, the high durability and impact resistance of the RAGE 2.0 means drivers don’t need to hold anything back over rough roads. The Readyset package comes fully assembled and includes everything except charger and battery for the chassis, and batteries for the transmitter. The beauty of the RAGE 2.0 is you can enjoy the thrill of on-road speed and the dynamic off-road action in one almighty machine and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Chassis With Reduced Screws
    Chassis features a reduced number and variety of screws by making frequently used screws the same size. Most screws are flat head screws that can be removed with a 2mm hex wrench for easy disassembly.
    Reliability and Features Abound
    Handling factors such as bump steer and scrub radius are optimized on the front suspension. Simple ball-connected steering knuckles provide reliable steering and suspension movement. Interchangeable front-rear and left-right hub carriers optimize spare parts utilization and improve maintenance efficiency.
    Light Handling and Precise Control
    New design rebuildable oil shocks mark an evolutionary step up from previous models. Optimal front-rear geometry and balance simultaneously delivers both light handling and precise control.
    Drive System Protection
    Equipped with slipper clutch to protect the drive system from the shocks of hard driving and jump landings as well as producing optimal traction.
    Wide Range of Gear Ratio Settings
    Standard spur and pinion gear is 75T and 22T, but 9 pinion gear settings can be used from 22T-30T to produce a wide range of gear ratio settings (When using pinion gear which is higher than 24T, it is recommended to change the motor). The new fixed gear mesh motor mount has holes for use with each pinion gear. Just simply mount the motor directly to the hole locations corresponding to the pinion gear. No gear mesh adjustment is necessary.
    All Terrain Tires and Wheels
    All terrain tires and wheels combine with oil shocks and suspension for balance and easy handling to realize dynamic performance over any terrain.
    Easy Handling
    Long travel rear suspension soaks up rough terrain and allows a balanced front rear weight transfer for easy handling. Rear hubs feature an insert so there are no left/right pieces for parts efficiency.
    New Powerful Motor
    Comes with the new powerful 550 size 14T brushed motor (G14L). The long can with Steel ring around the motor case and internal cooling fan provides efficient torque and high speeds.
    FEATURES:
    • New design shaft drive full-time 4WD buggy chassis (FZ02L-BT)
    • Factory-assembled Readyset package only requires 4 x AA alkaline batteries for the transmitter and battery with charger for the chassis to start running
    • Comes with the new powerful 550 size 14T brushed motor which provides efficient torque and high speeds
    • Equipped with 2-bevel grease-filled gear diffs on front and rear
    • Large size dog bones and cup joints provide superior reliability and durability
    • Strap mounted battery allows various battery types to be used
    • Full ball bearings that reduce drive loss equipped throughout the drive system
    • Includes KS202W waterproof steering servo
    • New design body in the image of American Rock Racers, features a vivid printed color scheme with decals applied
    • Performance can be further enhanced by installing various optional parts
    INCLUDES:
    • Kyosho Fazer Mk2 Rage 2.0 Red 1/10 Scale 4WD Truck - RTR
    • Completed chassis with R/C radio installed
    • Factory assembled body with decals applied
    • Syncro KT-231P+ transmitter
    • Installed 60A waterproof LiPo capable electronic speed controller (forward/brake/reverse)
    • Hex wrench
    • Spanner
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/10
    Length 390mm / 15.3in
    Width 281mm / 11.0in
    Height 165mm / 6.4in
    Weight (No Battery) 2080g / 73.3oz
    Wheelbase 274mm / 10.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 105mm x 52mm
    Wheel Hex Size N/A
    Tire Tread 235mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 10.49:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 60A
    Motor 550 size 14T brushed motor (G14L)
    Battery 4x AA alkaline and 1x 7.2V Ni-MH or 7.4V Li-Po up to 14.8V max (required)
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
