Official Kyosho 1/24 Scale Mini-Z 4X4 Suzuki Jimny Sierra Crawler Readyset 4WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Mini-Z 4X4 Suzuki Jimny Sierra Jungle Green Crawler Readyset 1/24 Scale 4WD Truck - RTR from Kyosho - KYO32523GR
    Mini-Z 4X4 Suzuki Jimny Sierra Kinetic Yellow Crawler Readyset 1/24 Scale 4WD Truck - RTR from Kyosho - KYO32523Y
    Version Info: This truck is delivered as "RTR", however does require 4x AAA batteries for the transmitter and 4x AAA batteries for the chassis, purchased separately (see Requires below for details).
    In 2019 the world's most popular mini RC series, known as the Kyosho MINI-Z, celebrated more than 20 years of unmatched performance and scale realism in the hobby-grade RC category. The continuous pursuit of performance and evolution has led to the creation of a completely-new ‘MINI-Z 4x4’ design that delivers an all-new driving experience for RC fans of all stripes, with superior overall design, driving performance and high-quality injection-molded scale body construction. A significant feature of the MINI-Z 4x4 series is the greater emphasis of body detail and quality of finish that even surpasses existing benchmarks set by the MINI-Z.
    The body is also molded with thicker material to better resist crash damage from operation in rough terrain. Incorporating the same ladder- style frame of real 4WD vehicles, the MINI-Z 4x4 boasts a 3-link rigid axle suspension combining what would normally be two upper links into a single upper A-arm to deliver maximum suspension movement. A specially designed high-torque steering servo enables this machine to throw its elbows around in the hard terrain for excellent performance in the toughest rock-crawler conditions. The high-torque 130-size motor brings out the beast in the MINI-Z 4x4, specially geared to run well in the low to medium speed ranges common in crawling.
    Designed to balance exquisite style, scale detail and superior driving performance, all the MINI-Z 4x4 needs is 8 x AAA alkaline batteries (sold separately). Enjoy driving under any conditions, from normal driving to rock crawling while appreciating the stunning visual appearance. The Kyosho Mini-Z 4x4 is the only mini crawler that delivers a full range of crawling performance in a smaller package.
    Your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    KT-531P Transmitter
    Includes stylish Syncro KT-531P transmitter. Features steering / throttle trim as well as steering dual rate adjustment and LED control function.The transmitter also has a Training Mode feature which limits speed of the car for easy learning(Default setting at the time of shipment is Training Mode).
    Gyro Compatibility
    Style, Scale Detail and Performance
    This Mini-Z 4x4 exhibits the perfect blend of style, scale detail and exceptional driving performance.
    FEATURES:
    • The perfect balance of exquisite style, scale detail and superior driving performance
    • The body is molded with thicker material to better resist crash damage from operation in rough terrain
    • Incorporates the same ladder- style frame of real 4WD vehicles
    • 3-link rigid axle suspension delivers maximum suspension movement
    • High-torque steering servo for excellent performance in the toughest rock-crawler conditions
    • High-torque 130-size motor specially geared to run well in the low to medium speed ranges common in crawling
    INCLUDES:
    • Kyosho Mini-Z 4X4 Suzuki Jimny Sierra Jungle Green Crawler Readyset 1/24 Scale 4WD Truck - RTR
    REQUIRES:
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 11 AND UP
    SKILL LEVEL : BEGINNER
    BUILD TIME : NONE
    Model Scale 1/24
    Length 193mm / 7.5in
    Width 84mm / 3.3in
    Height 90mm / 3.5in
    Weight (No Battery) 242g / 8.5oz
    Wheelbase 120mm / 4.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD (MX-01)
    Drivetrain N/A
    Wheel Size (Diameter x Width) 37mm x 37mm
    Wheel Hex Size N/A
    Tire Tread 72.7mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 55.44:1/ 30.80:1/ 46.20:1/ 27.72:1/ 39.60:1/ 34.65:1
    Final Drive Ratio N/A
    Pinion 10T- 20T
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor 130 Class
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Outdoors, smooth to rugged surfaces
