Official Kyosho 1/10 Scale Monster Tracker 2.0 4WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Monster Tracker 2.0 Blue 1/10 Scale 4WD Truck - RTR from Kyosho - KYO34404T1
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter (see Requires below for details).
    Nothing stands in the way of the Monster Tracker as it clears jumps and gaps in the road with ease, leaving everything behind in a trail of dust. The pickup truck body rides high and proud in true American style on tires that are big and wide, just like the country of its birth. Power over and through fields with this affordable monster truck that is built tough for carefree excitement. A one-touch hatch allows the chassis to be easily accessed for battery changes. The dust-proof radio box and diff gear case combine with break-resistant flexible resin material so in the rare event of a breakage, easy replacement and assembly provide beginners with peace of mind. Simply insert 4 x AA-size batteries (sold separately) in the transmitter and charge the battery for the chassis and this factory-assembled Readyset truck is ready to rumble. Start your R/C journey on the right track with the Monster Tracker and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Bumpers Built For Protection
    Strong bumpers on front and rear protect the chassis and body from crash damage.
    Easily Accessible Battery
    The battery pack is easily accessed with one-touch opening of the hatch for fast battery changes, without the need to remove the body.
    Battery and Charger Included
    Readyset features Kyosho Speed House 7.2V-2200mAh NiMH battery and Delta Peak USB Charger (with T-Connector).
    Dynamic Suspension Range
    Double wishbone suspension combines with coil-over shocks on all four wheels and threaded spring pre-load adjusters for chassis height for dynamic suspension range.
    FEATURES:
    • Newly designed gear box eliminates the need for messy backlash adjustment
    • Factory assembled Readyset only requires charging the chassis battery and adding four AA-size alkaline batteries (sold separately) for the transmitter
    • Includes new 2.4GHz Syncro KT-232P transmitter
    • Precision modules on differential gear for high durability
    • Fixed length sus arms eliminate need for precision adjustment of alignment
    • Newly designed servo saver protects the servo from crash impact and improves steering feel
    INCLUDES:
    • Kyosho Monster Tracker 2.0 Blue 1/10 Scale 4WD Truck - RTR
    • Factory assembled chassis with built in R/C unit
    • Factory finished body with decals applied
    • Syncro KT–232P transmitter
    • Cross Wrench
    • Delta Peak USB Charger
    • 2200 NiMH battery
    • Instruction manual
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : BEGINNER
    BUILD TIME : 1 HOUR
    Model Scale 1/10
    Length 410mm / 16.1in
    Width 300mm / 11.8in
    Height 175mm / 6.8in
    Weight (No Battery) 1900g / 67.0oz
    Wheelbase 270mm / 10.6in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 110mm x 70mm
    Wheel Hex Size N/A
    Tire Tread 230mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 11.27:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor N/A
    Battery 4x AA (required)
    Servos N/A
    Radio Syncro KT–232P transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
