Official Kyosho 1/10 Scale Monster Tracker T1 2WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Monster Tracker T1 Green 1/10 Scale 2WD Truck - RTR from Kyosho - KYO34403T1B
    Monster Tracker T1 Orange 1/10 Scale 2WD Truck - RTR from Kyosho - KYO34403T2B
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter (see Requires below for details).
    Nothing stands in the way of the Monster Tracker as it clears jumps and gaps in the road with ease, leaving everything behind in a trail of dust. The pickup truck body rides high and proud in true American style on tires that are big and wide, just like the country of its birth. Power over and through fields with this affordable monster truck that is built tough for carefree excitement. A one-touch hatch allows the chassis to be easily accessed for battery changes. The dust-proof radio box and diff gear case combine with break-resistant flexible resin material so in the rare event of a breakage, easy replacement and assembly provide beginners with peace of mind. Simply insert 4 x AA-size batteries (sold separately) in the transmitter and charge the battery for the chassis and this factory-assembled Readyset truck is ready to rumble. Start your R/C journey on the right track with the Monster Tracker and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Ready To Run!
    Readyset features Team ORION 7.2V-1800mAh Ni-MH battery rocket pack and an AC charger (with Deans-type connector).
    Adjustable Suspension
    Double wishbone suspension combined with coil-over shocks and threaded spring pre-load adjusters for chassis height adjustment.
    Terra Tires
    Wide, large-diameter “Terra” tires dominate any running surface, including sand, dirt, grass and asphalt.
    KT-232P Transmitter
    Includes 2.4 GHz Syncro KT-232P transmitter that automatically manages frequency bands. Features adjustable trim, servo reverse and steering dual rate.
    Easy Battery Access
    The battery pack is easily accessed with one-touch opening of the hatch for fast battery changes, without the need to remove the body.
    Easy Motor Install
    The powerful 540-class motor of the Monster Tracker can be installed/uninstalled by loosening four screws.
    FEATURES:
    • Factory assembled Readyset only requires charging the chassis battery and installation of four AA-size alkaline batteries (sold separately) for the transmitter
    • Includes new 2.4GHz Syncro KT-232P transmitter
    • Fixed length upper arms eliminate need for alignment adjustments
    • Steering servo horn is equipped with servo saver to protect the servo from crash impact
    • Compatible with a wide range of optional parts for the Sand Master
    INCLUDES:
    • Kyosho Monster Tracker T1 Green 1/10 Scale 2WD Truck - RTR
    • Factory assembled chassis with built in R/C unit
    • Factory finished body with decals applied
    • Syncro KT–232P transmitter
    • ESC installed (forward, brake, reverse)
    • Cross Wrench
    • 7.2V-1800mAh Ni-MH battery
    • AC Charger
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/10
    Length 410mm / 16.1in
    Width 300mm / 11.8in
    Height 175mm / 6.8in
    Weight (No Battery) 1900g / 67.0oz
    Wheelbase 270mm / 10.6in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 110mm x 70mm
    Wheel Hex Size N/A
    Tire Tread 230/230mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Aeration
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 11.27:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor 22 turn 540 type
    Battery 7.2V 1800mAh NiMH battery (required)
    Servos N/A
    Radio Syncro KT-232P transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time none
    Recommended Environment Offroad
