Official Kyosho 1/10 Scale Outlaw Rampage Pro 2WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Outlaw Rampage Pro Red 1/10 Scale 2WD Truck - RTR from Kyosho - KYO34363T1
    Outlaw Rampage Pro Gold 1/10 Scale 2WD Truck - RTR from Kyosho - KYO34363T2
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.2V 1800mAh NiMH battery and a battery charger, purchased separately (see Requires below for details).
    The Outlaw Rampage Pro adds a realistic roll cage to the time-tested performance platform inside Kyosho's new 2WD Trophy Truck. With a mechanism based on the actual full-size truck, the result is an enhanced RC driving experience that is more fun than ever! With a new chassis designed from the ground up, the chassis features double wishbone suspension on the front with a link system on the rear in combination with the long stroke high volume aerated shocks to deliver a high performance standard worthy of a 2WD Trophy Truck.
    This vehicle's heavy-duty drive system provides exceptional reliability with it's 32 pitch gear setup and slipper clutch that soaks up load changes to the drive chain. With a power center combination consisting of the "G15" brushed motor and Vortex WP Brushed ESC 45A, the performance of the Outlaw Rampage is matched by its stunning 1970-80's trophy truck style with pre-cut and painted body. Whether it's the rough road or no road at all, the Outlaw Rampage Pro puts the ultimate R/C experience in your hands.
    Your Kyosho truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    The chassis is worthy of the 2WD trophhy truck motif. Solid rear axle differential with link rear end system delivers smooth suspension and traction for superior performance.
    Two Chassis Mounting Positions
    Two chassis mounting positions for the rear links allow setup to suit different driving conditions. It is also designed to be used with shorter links for future developments.
    High Traction and Stability
    Long suspension arms on the front double wishbone suspension deliver high traction and stability. It reflects real car mechanics, as does the rear link suspension.
    Large Capacity Aeration Shocks
    Large capacity aeration shocks (non bladder) enable a long suspension stroke in combination with the front and rear suspension.
    Scale Tread Pattern
    The tires feature an original tread pattern to deliver performance and style that matches the appearance of the scale body. Tires are fixed to the 3-piece wheel structure with screws so no gluing is required.
    Scale Appearance and Realism
    With the addition of the previously optional rear roll cage, performance and tuning options have been increased. As well as a more "scale" look.
    Added Strength
    32-pitch counter gear and gear diff inside the gearbox provide added strength. Adjustable slipper clutch is equipped with a 48 pitch spur gear.
    Easy Battery Removal
    Easy battery removal is possible with the lever lock battery closure. Radio plate with connector holder allows connection or disconnection with a single hand.
    FEATURES:
    • Realistic roll cage adds more scale-oriented look and performance
    • New chassis design features double wishbone suspension on the front with rear link system
    • Long stroke high volume aerated shocks
    • Heavy-duty drive system exhibits high durability and reliability
    • "G15" brushed motor and Vortex WP Brushed ESC 45A power system
    • Stunning 1970-80's trophy truck style with pre-cut and painted body
    INCLUDES:
    • Kyosho Outlaw Rampage Pro Red 1/10 Scale 2WD Truck - RTR
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/10
    Length 561mm / 22.0in
    Width 262mm / 10.3in
    Height 231mm / 9.0in
    Weight (No Battery) 2400g / 84.6oz
    Wheelbase 335mm / 13.1in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 108mm x 38mm
    Wheel Hex Size N/A
    Tire Tread 204mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Aeration
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 12.65:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 45A
    Motor 5 turn 540 type (G15 motor)
    Battery 7.2V 1800mAh NiMH battery (required)
    Servos N/A
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1 Hour
    Recommended Environment Offroad
