Official Kyosho 1/10 Scale Ultima SC6 Readyset 2WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Ultima SC6 Readyset 1/10 Scale 2WD Truck - RTR from Kyosho - KYO30859B
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.2V 1800mAh NiMH battery and a battery charger, purchased separately (see Requires below for details).
    The short course trucks taking the world by storm in The Off Road Championship (TORC) in America are now available as R/C machines. Joining the Ultima SC (Readyset) and competition specification Ultima SC-R (unassembled kit) is Kyosho's 3rd model in this fast growing series; the Ultima SC6. Based on the 2013 Electric Off-Road World Championship RB6 design, the Ultima SC6 has been modified for optimal short course performance from race data and driver feedback.
    Superior turning performance from the mid-ship layout, smooth suspension movement with big bore aeration oil shocks and minimal drive loss due to the gear differential all combine to deliver dynamic performance on off-road circuits, especially high-grip surfaces. Equipped with the newly developed dDrive, this one-piece ESC and brushless motor power unit allows precise adjustment to realize the ideal throttle feel.
    The Readyset also comes with a newly designed pre-cut and printed body and KT-331P transmitter with LCD screen. Simply add your own battery to the chassis and the transmitter and you can be enjoying the dynamic performance of real short course truck racing and your Kyosho truck is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    More Power and Performance
    Installed with Team Orion's dDRIVE one-piece ESC and brushless motor. Simple wiring and setting options allow precision adjustment of control feel.
    Improved Driveability
    Aluminum main chassis delivers moderate flex and high strength. Milling process produces optimal chassis rigidity for excellent controllability from improved grip.
    Dramatically Improved Grip
    Precision machine cut aluminum aeration big bore oil shocks deliver dramatically improved grip.
    High Grip Block Pattern Tires
    High grip block pattern tires with sponge inners combine with hi-vis neon yellow wheels.
    Precision Adjustment
    Slipper clutch prevents damage to the gears from excessive loads during jumps. Precision adjustment to suit driving surface conditions delivers high acceleration.
    Radio and Battery Protection
    Side bumpers installed on both sides of chassis protects the R/C radio and battery from impact.
    Adjustable
    Equipped with easily adjustable turnbuckles on steering tie rod and upper arms. Adjust rod length for precision setting of front/rear camber and front toe angle.
    High Torque and Waterproof Servo
    High torque and waterproof KS-4031-06W servo delivers optimal off-road performance. Servo saver protects servo from hard impact.
    2.4GHz KT-331P Transmitter
    2.4GHz KT-331P transmitter features LCD screen for setting functions such as sub-trim, end point and dual rate adjustment. Also includes KR-331 receiver.
    FEATURES:
    • Short course truck design based on the 2013 Electric Off-Road World Championship RB6
    • Factory assembled chassis requires only batteries for chassis and transmitter
    • Newly designed 0.8mm polycarbonate printed body delivers exceptional aerodynamics
    • Features race-standard midship layout for nimble movement on high grip surfaces
    • Equipped with oil-filled gear differential that maintains performance over long periods with excellent maintenance characteristics
    • Choose either 25° or 30° front skid to produce optimal running performance over gaps and jumps
    • Hex-type screws tighten firmly and are easy to work with
    • Tune up your chassis performance with a wide range of compatible RB6 optional parts
    • Gearbox incorporates two optional (UMW513 SP idler gear) hardened idler gears as standard
    INCLUDES:
    • Kyosho Ultima SC6 Readyset 1/10 Scale 2WD Truck - RTR
    • Factory assembled chassis with R/C unit installed
    • Painted body complete with decals applied
    • Syncro KT-331P transmitter
    • Hex wrench (1.5, 2.0, 2.5mm)
    • Cross wrench
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/10
    Length 550mm / 21.6in
    Width 296mm / 11.6in
    Height 150mm / 5.9in
    Weight (No Battery) 2000g / 70.5oz
    Wheelbase 330mm / 12.9in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 110mm x 44mm
    Wheel Hex Size N/A
    Tire Tread 246/248mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Aeration
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 10.95:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor Brushless
    Battery 7.2V 1800mAh NiMH battery (required)
    Servos N/A
    Radio Syncro KT-331P transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1 Hour
    Recommended Environment Offroad
