Official XK Innovations 1/12 Scale Military Truck 4WD Truck - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Military Truck Gray 1/12 Scale 4WD Truck - RTR from XK Innovations - WLT-124302-200
    Military Truck Tan 1/12 Scale 4WD Truck - RTR from XK Innovations - WLT-124302-100
    The XK Innovations 124302 Military Truck is a 1/12 scale truck that arrives to your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Rubber Tires
    Powered by a 390 size electric motor drivetrain, the smartly molded rubber tires provide excellent traction.
    Customizable
    A classic body plan makes this truck very versatile. Perfect for small scale dioramas and RC militaria, this truck is a cost-effect base for your own customization and detailing!
    Ready To Run (RTR)
    Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v Li-Ion battery, pre-installed headlight LEDs, and convenient battery charger are included.
    Heavy Load Capacity
    Load up to 1200g worth in the truck bed for transport along flat surfaces.
    FEATURES:
    • Full Functions: Forward, backward, turn left, turn right, trim
    • ~15km/h (~10mph) speed, approximately double the scale speed
    • 4WD drive system and powerful 390-size electric motor
    • Headlight LEDs
    • 2.4G remote controller enables high interference resistance and excellent control
    • Realistic-looking tires provide solid performance and stability
    • The maximum load on flat pavement can reach up to 1200g, and the maximum load on uphill pavement can reach up to 500g
    INCLUDES:
    • XK Innovations Military Truck Gray 1/12 Scale 4WD Truck - RTR
    • 2.4GHz Transmitter and charger
    • 2S 7.4V 850mAh LiPo with JST-Connector
    REQUIRES:
    • Four (4) AA size batteries for the radio transmitter
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : NONE
    Model Scale 1/12
    Length 450mm / 16.0in
    Width 180mm / 10.0in
    Height 200mm / 5.7in
    Weight (No Battery) 1233g /
    Wheelbase 260mm
    Ground Clearance 30mm
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 88mm x 33mm
    Wheel Hex Size 4mm
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type Leaf Spring
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 45A (included)
    Motor 390 Motor brushed
    Battery 2S 7.4V 850mAh LiPo with JST-Connector
    Servos 1 steering servo
    Radio 2 Channel
    Lights Yes
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
  • keilau
    • Mar 2021
    • 1849
    • Windy City
    The feature include "electronic speed control, 45A" and "steering servo". But it is strange that it does not mention proportional speed control and steering control. Are both proportional?
