Grand Hauler Custom Build
  • Grand Hauler Custom Build
    Well, I have wanted to build one of these bad boys for at least the past 10 years so here we go!
    Drive shaft upgrade.
      Feel free to ask questions. This is my my build so learning myself about these amazing trucks.
        More pics as I move slowly along.
          More pics. Made my own custom release for the hitch.
            Battery boxes slash steps.
              Fuel tanks.
                Working on lighting the dash.
                  Moved the speaker to the front of the truck so I can do the interior. Used a small Glad container cut down to fit over the speaker. Held by some tape then glued on with foamtac. Double faced taped it to the servos for mounting.
                    Pics.
                    • #11
                      Rear bumper lighting. I added two extra small LED's for the side markers. These will work off a second switch. I also found their stock running lights to be too bright. I used a resistor to dim them down a bit.
                      • #12
                        Here is a video of the rear lighting in action. https://www.youtube.com/watch?v=_nuhrWg_K3A
                        • #13
                          I had some plastic rectangular tubes sitting around. So cut one side open to make it a C channel, painted it green. Then made a box around what use to be the plastic chrome grill of the truck and made a cover for the rear over the frame rails.
                          • #14
                            Going to add lighting to the stock front bumper.
                            • #15
                              Here is the wires ran from the back bumper up to the cab in wire loom.
                              • #16
                                This is where I will attach any other lights I am using that is hooked up to my power switch. https://www.motionrc.com/products/gt...ch-gtpelswitch
                                • #17
                                  Here is the lighted front bumper with fog lights. https://www.youtube.com/watch?v=xjlLYUQw74g
                                  • #18
                                    Starting my body work to turn this into a Peterbilt. Ground out the old headlight buckets and filling in with plastic as best I can before using putty.
                                    • #19
                                      Nice work! That is quite a project.
                                      • #20
                                        Bought some tool boxes to mount behind my fuel tanks. Took some time to polish them up a bit.
