Official XK Innovations 1/10 Scale Wrangler 4WD Crawler RTR Thread
    Wrangler 1/10 Scale 4WD Crawler – RTR from XK Innovations - WLT-104311
    Please be aware:
    This product, although 2.4GHz R/C, is intended for first-time, younger users. The steering and throttle are not proportional. Turning the transmitter steering wheel in any amount delivers 100% turning (right or left) and same with forward/reverse throttle when operating the throttle. Most youngsters do this anyway when first driving an R/C vehicle!
    In addition, the XK Innovations 104311 Wrangler 1/10 Scale 4WD Crawler features realistic scale appearance details and even powerful LED lights for night driving. The realistic crawler chassis features solid axles, link-style suspension, and realistic spring dampers deliver a fun driving experience. The twin-280 motors, one on each axle, provide the vehicle with power while eliminating maintenance-intensive driveline components, while the built in, rechargeable battery pack delivers run times of 20-30 minutes.
    Even with all of those features, you may like the Wrangler’s realistic appearance so much that it never leaves the display shelf! Regardless of its ultimate parking spot, this vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Complete Package
    From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK Wrangler 1/10 Scale 4WD Crawler is truly complete. Simply add 4 AA alkaline batteries for the transmitter (not included) and it’s ready for supreme driving action!
    Capable Scale Chassis Design
    Unlike lesser models, this vehicle features a durable, traditional crawler “ladder” chassis layout that delivers realistic performance.
    • Functions: non-proportional forward, backward, turn left, turn right, LED lights
    • Interference-free 2.4GHz radio technology
    • Perfect for youngsters to learn to drive RC!
    • Coil-over spring dampers
    • Dual-motor 4WD system
    • XK Wrangler 1/10 Scale 4WD Crawler – RTR
    • 2.4GHz Transmitter
    • 7.4v 1200mAh LiPo battery
    • USB-Powered LiPo Battery Charger
    • Screwdriver
    • Instructions
    AGE LEVEL :5 and up
    SKILL LEVEL :beginner
    BUILD TIME :none
    Model Scale 1/10
    Length 472mm / 18.4in
    Width 268mm / 10.5in
    Height 227mm / 8.8in
    Weight (With Battery) 1740g / 62.1oz
    Wheelbase N/A
    Ground Clearance 47mm / 1.8in max
    Body Polycarbonate, factory painted and decorated
    Chassis Nylon composite
    Drivetrain 4WD
    Wheel Hex Size N/A
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Coil Over Dampers
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Gear
    Ball Bearings No
    Brakes Electronic
    Electronic Speed Control Yes
    Motor 280 Brushed x 2
    Battery 2S LiPo (included)
    Servos N/A
    Radio 2 Channel (included)
    Lights Yes
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time None
