Official Team Corally 1/8 Scale Punisher Monster Truck RTR Thread
    • 8228
    Punisher XP 2021 LWB 1/8 Scale 4WD Monster Truck - RTR from Team Corally - COR00171
    Motion RC is proud to represent the Team Corally brand of high quality surface RC vehicles, including this stunning 1/8 scale Punisher XP 2021 4WD Monster Truck. Delivered Ready to Run ("RTR") with all onboard electronics pre-installed, simply add your 2S-6S LiPo battery with XT90 connector and your preferred charger and this beast is ready for exciting off-road adventures!
    Want to dominate the track and stay ahead of your friends? The Punisher is going to be at the top of the timing sheet! The Punisher from Team Corally is simply the meanest, baddest and roughest LiPo-powered truck on the planet. Fitted with a 2050KV motor that can take up to 6S power, the Shogun is super-fast on dirt, gravel, grass, jumps and more! If you want massive speed and huge air in a racing truck package, you have found your perfect vehicle.
    With a super-durable, all-metal four-wheel drivetrain, fully independent competition-style suspension, racing chassis and aerodynamic racing design, this is the ultimate basher truck for anyone looking for massive jumps and frightening speeds!
    Self-Centering Competition-Grade Roll Bar System
    The Team Corally Shogun features a self-centering competition-grade anti-roll bar system factory-tuned to perfection.
    Aluminum Reinforced Suspension
    Precision machined CNC aluminum shock towers and an aluminum reinforced suspension provide exceptional off-rad durability.
    4mm Hard Chrome Plated Spring Steel Turnbuckles
    Corrosion resistant spring steel turnbuckles strike the perfect balance between strength, durability, flexibility, and adjustability.
    Pre-Installed Electronics
    The Shogun arrives with pre-installed electronics including the radio transmitter, receiver, 2050Kv brushless motor, splashproof 150A ESC, and steering servo. Simply add your AA batteries for the radio and your main LiPo drive battery into the vehicle.
    16mm Big Bore Aluminum Shocks
    Adjustable big bore 16mm aluminum body shocks deliver positive traction and a confident ride over any bump and obstacle. Tune the stiffness to your preferences in seconds by rotating the threaded adjustment nut up or down.
    All Metal Drivetrain with Oversized Bearings
    Survive punishing bashing sessions with the Shogun's durable all-metal drivetrain supported on oversized bearings.
    Heavy Duty Aluminum Sliding Motor Mount
    Dial in a perfect gear mesh with the durable aluminum adjustable sliding motor mount. The mount's sliding design also facilitates easy motor removal to service the pinion and clean debris after especially rough driving.
    RTR - "Ready To Run"
    With the majority of electronics pre-installed at the factory, simply add your chosen 2S-6S LiPo battery and charger (not included) to begin dominating the nearest RC track or trail!
    CNC-Machined Steel Geared Differentials
    The CNC-machined steel geared differentials offer rock-solid performance and durability each and every time.
    1/8 Scale
    The 1/8 scale size is a perfect blend of presence and ease of transport.
    • Pre-built racing style truck with electronics, bodyshell and tires installed
    • Team Corally TOROX 185 150A ESC 3-6S with LiPo protection (programmable)
    • Team Corally Kuron 2050Kv 4-pole brushless motor 2-6S
    • Varioprop® CR-7220-MG High Torque Digital Servo, Metal Gear, 20 Kg Torque
    • Aluminium servo arm
    • Ergonomic Varioprop® S2R transmitter, with interference-free 2.4GHz technology
    • Separate splash-proof and dustproof electronic box with transponder mount
    • Adjustable battery holder for all common LiPo batteries
    • Full set of ball bearings, rubber sealed
    • All transmission ball bearings are 8x16x5mm
    • Hardened steel spur gear and motor pinion
    • Three silicone fluid-filled + sealed metal differentials with quick access design
    • Quick + Easy diff access
    • 2-piece aluminium motor holder with composite gear cover
    • Complete metal drive train
    • Steel front CVD joints
    • Aluminium 17 mm drive hexes
    • Oil-filled threaded 16 mm aluminium Big Bore shocks
    • Team Corally SPL shock spring perches locking system
    • Milled aluminium shock towers, 5mm rear / 4mm front
    • Independent Pivot Ball front suspension
    • Independent double wishbone rear suspension
    • Reinforced truck front steering blocks and rear hubs
    • Aluminium suspension mounts with composite cover
    • Full set of machined steel turnbuckles with 7mm hexes
    • Individually adjustable chassis and steering geometry
    • Team Corally RSP anti-roll bar system, front + rear
    • Aluminium chassis plate
    • Bashproof double chassis brace system
    • Front bumper with chassis protection
    • Centre Roll cage mount
    • Reinforced high downforce wing + adjustable wing holder
    • Pre-glued low-profile multi-pin pattern tyres on black 7-spoke nylon rims
    • Sturdy, elaborately printed polycarbonate body
    • Huge selection of custom tuning products available
    • 110+ km/h (70+ mp/h) possible
    • Team Corally Punisher XP 2021 LWB 1/8 Scale 4WD Monster Truck - RTR
    • Team Corally TOROX 185 150A ESC 2-6S with LiPo protection (programmable)
    AGE LEVEL :11 and up
    SKILL LEVEL :intermediate
    BUILD TIME :none
    Model Scale 1/8
    Length 590mm / 23.2in
    Width 455mm / 17.9in
    Height 219mm / 8.6in
    Weight (No Battery) 4700g / 165.7oz
    Wheelbase 384mm / 15.1in
    Ground Clearance 70mm / 2.7in
    Body Composite
    Chassis Painted, Decals Applied, Trimmed
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 145mm x 70mm
    Wheel Hex Size 17mm
    Tire Tread Offroad
    Bushing Material Plastic
    Suspension Independent
    Shock Type Oil Filled, Coil Over, Adjustable
    Transmission 2 Speed
    Gear Pitch
    Internal Gear Ratio
    Final Drive Ratio
    Pinion
    Spur Gear
    Differential Oil Filled, Metal Bevel Gear, Locked
    Ball Bearings Transmission Only
    Brakes Electronic
    Electronic Speed Control 150A, Waterproof w/ XT90 Connector
    Motor 2050Kv Brushless Inrunner
    Battery 2S - 6S LiPo with XT90 connector (required)
    Max Battery Dimensions (L x W x H) 51 x 142 x ?mm (2 x 5.5 x ?")
    Servos Waterproof, Metal Gear
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time Less Than 1 Hour
    I had this truck since may, and oh yeah, she's a beast on 6s, tons of fun, i did replace the controller with my dx5 rugged. I'm not sure if on the stock radio it's different, but with the dx5 being the only mod I've done to it, it feels predictable even at speed. That said, 6s definitely requires your entire attention, and is definitely not for anyone not adapted to high speed, high powered rc driving.
    • Cecil
      • Sep 2022
      • 19
      • United States
      I'm more into propeller airplanes than trucks. But this one seems tempting.
