Official Kyosho 1/8 Scale USA-1 GP .25 Engine MT Monster Truck 4WD Thread
    USA-1 GP .25 Engine MT 1/8 Scale 4WD Nitro Monster Truck - RTR from Kyosho - KYO33155
    Version Info: This car is delivered as "RTR", however it does require 4x AA batteries for the transmitter, and 4x AA batteries for the receiver. This is the nitro version which also requires glow fuel, fuel bottle and plug heater (see Requires below for details).
    The original Kyosho Nitro USA-1 set the standard for RC Monster Truck power and performance when it was released in 1990. 30 years later, the torch has passed to the newest Nitro USA-1, which outperforms the original in EVERY respect. Yes, it's that much better… and we even build it for you.
    Built on a pickup truck chassis, large diameter tires and big engines with massive horsepower were installed by fun-loving American off-roaders to create the monster truck. These ever-popular monster trucks can be seen on specially-made racing circuits or jumping rows of cars in stadiums across the USA. Many R/C monster truck models have been produced over the years. First among equals is the legendary 1/8 scale USA-1 that embodied the might of American trucking power during the 1980’s and 90’s. Officially licensed by Kyosho in the 1990’s, the R/C model uniquely captured the power and glory of the USA-1. Now it’s ‘comeback-time’ for the USA-1, with modern chassis and drivetrain technology, upgrades unique to the USA-1 throughout, and a newly-designed ‘ULTRA SCALE BODY’ with form and detail finished to display-model standards.
    The iconic American flag graphic emblazoned on the body makes your heart swell with pride! The chassis features shaft-driven 4WD and 5-link suspension based on the Mad Crusher 2.0 & FO-XX models. Most of the suspension components have been uniquely upgraded and reinforced for the USA-1 at each point to handle the powerful new KE25SP2 engine, and the rigors of monster trucking. A 3-speed automatic transmission produces dynamic acceleration, which is enhanced by a true suspension system to produce "scale" running characteristics worthy of the prestigious USA-1, and make you feel like a monster truck driving god. Released as a pre-assembled Readyset, the USA-1 is almost ready for action straight out of the box and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Scale Details
    Molded and chrome-plated triple carburetors look identical to those used on the real truck, which looks awesome sticking through the hood once the body is attached. Coupled with the growl of the powerful engine, this accessory creates even more original details of the USA-1 more than ever.
    Easier To Adjust Engine
    Equipped with a new KE25SP2 engine, the easier-to-adjust low-speed needle makes it easier to produce more power than the previous KE25SP engine. The engine is fitted with a pull starter so a starter box isn’t required and engine settings have been optimized at the factory.
    Transmission Utilizes Full Power
    The time-tested 3-speed automatic transmission effectively utilizes the full power of the engine. In the low speed range, the torque of the engine is optimized by the ratio of first gear, while the 2nd gear covers the medium speed range where torque tends to be insufficient. Acceleration to maximum speed is achieved smoothly and efficiently.
    Superior Traction and Handling
    A 5-link suspension platform controls the rigid front and rear axles to minimize drive loss and deliver superior traction and handling over uneven and varying running surfaces. The large-capacity oil shocks reliably help to absorb the impacts from the running surface.
    • Pre-assembled chassis with R/C system installed and finished body. Includes pistol-grip Synchro KT-231P+ transmitter
    • 5-link suspension in combination with shaft-type 4WD delivers exceptional stability over rough roads
    • Equipped with KS5031-09MW servos that incorporates durable metal gears
    • Ultra-realistic scale body has been recreated under license of USA-1, including the signature color scheme
    • Optional LED light set shines bright with LED head & tail lamps and rooftop fog lamps
    • Equipped with a new KE25SP2 engine with easy needle setting. Also includes break-in ring to get the engine safely prepared for harder running
    • Gleaming polished tuned muffler is equipped as standard
    • Front center drive features a telescopic universal shaft to ensure high drive efficiency and prevent shaft dropout issues
    • Optional 4WS (four wheel steering) increases turning power. A wide range of other option parts are also available
    • Electric version using the same body and chassis components is also available
    • Kyosho USA-1 GP .25 Engine MT 1/8 Scale 4WD Nitro Monster Truck - RTR
    • Pre-assembled chassis with pre-set control linkages
    • Pre-cut and painted body complete with decals applied
    • 2.4GHz Syncro KT-231P+ transmitter
    • L shaped hex wrench (1.5mm, 2.0mm, 2.5mm, 3.0mm)
    • Cross wrench (large)
    • 17mm wheel wrench
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :1 hour
    Model Scale 1/8
    Length 567mm / 22.3in
    Width 455mm / 17.9in
    Height 297mm / 11.6in
    Weight (No Battery) 5040g / 177.7oz
    Wheelbase 360mm / 14.1in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 164mm x 104mm
    Wheel Hex Size N/A
    Tire Tread 339mm / 343mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 25.7/19.8/15.6:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor Kyosho KE25SP2 glow engine with recoil starter
    Battery 8x AA alkaline (required)
    Servos N/A
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Go nuts
