Official XK Innovations Across 1/12 Scale 4WD Short Course Truck Thread
  • jbaartz
    • Sep 2020
    • 488
    Across 1/12 Scale 4WD Short Course Truck - RTR from XK Innovations - WLT-12423-001
    The XK Innovations 12423-001 Across Short Course Truck is a 1/12 scale 4WD vehicle that is tuned for off-road action, yet capable of top speeds over 25MPH! In addition to a durable composite chassis and convenient access to electronics, the independent front suspension with individual coil-over dampers is perfect for high-speed runs on the flats or aggressive performance in all types of terrain. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Easy-Access Components
    RC fans will notice the realistic chassis layout with independent front suspension and a durable, reliable solid axle rear suspension. The brushed 540 motor, ESC, and battery are all easily accessible.
    Interference-free 2.4GHz Radio System
    Drive with confidence when using the comfortable and reliable 2.4GHz radio system included with your XK Across!
    • Functions: Fully proportional forward, backward, turn left, turn right
    • Interference-free 2.4GHz radio technology
    • Tackles all terrain and conditions
    • Coil-over shock absorbers
    • Composite tub-style chassis design for supreme durability
    • Geared differentials
    • 4WD system provides plenty of power with impressive acceleration
    • XK Across 1/12 Scale 4WD Short Course Truck - RTR
    • 2.4GHz Transmitter
    • 2S 7.4V 1500mAh LiPo battery with T-connector
    • USB-Powered LiPo Battery Charger
    • Cross-wrench and Instructions
    AGE LEVEL : 12 Years and Up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/12
    Length 420mm / 16.5in
    Width 225mm / 8.9in
    Height 155mm / 6in
    Weight (No Battery) N/A
    Wheelbase N/A
    Ground Clearance 51mm / 2in max
    Body Polycarbonate, factory painted and decorated
    Chassis Composite
    Drivetrain 4WD
    Wheel Hex Size 14mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Coil Over
    Transmission F/R Differentials, Center shaft
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Composite Bevel Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Yes
    Motor 540 Brushed
    Battery 2S LiPo battery with T-connector (included)
    Servos Splash-proof, 5-wire
    Radio 2 Channel (included)
    Lights Yes
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time None
