Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter.
The ROC Hobby Kubelwagen 1/12 Scale 4WD Military Truck RTR from Motion RC is the perfect addition to any military scale RC collection. Known as the “bucket” or “tub” car, the Kübelwagen Type 82 was a light military vehicle designed by Ferdinand Porsche and built by Volkswagen during WWII for military use. It was the axis equivalent of the “Jeep” although the production quantity of approximately 50,000 was far less than the 650,000 of its famous US counterpart.
The model features a strong load-bearing chassis with stamped central spine that protects and covers the center drive shaft and electrical wiring. This molded unibody features the texture of the original full-size metal stamping with plastic reinforcement areas to accurately reproduce features of the actual car. The front and rear wheels adopt a torsion spring independent suspension, allowing a surprising amount of suspension travel while maintaining a compact size. The highly detailed injection-molded plastic body and realistic interior combine to create a model you’ll be proud to own and operate. Additional unique details can be found in the engine bay, where a magnificent scale engine hides a small electric motor that realistically turns the belts and pulleys to power the cooling fan when the vehicle is running!
The 4 channel pistol-grip transmitter features capabilities to shift between low and high speed operation as well as selecting RWD or 4WD driving modes, making this vehicle capable of tackling most any terrain. There is also an automatic integrated lighting control system, which allows you to turn on the headlights during normal night driving, with linked turn signals and brake lights are at the rear of the car. As with other scale military models from FMS/ROC Hobby, the steering wheel and axle are linked. When you turn the wheel on the transmitter, the steering wheel does the same. A 2-in-1 receiver/ESC unit offers precise and reliable control, while the 1/12 scale size is ideal for use with various military doll figures (not included).
Combine the scale fidelity and “drive anywhere” fun of the Kubelwagen 1/12 Scale 4WD Military Truck RTR with Motion RC’s industry-leading customer service and product support for a product that you’ll be proud to add to your collection!
Comfortable, Reliable 2.4GHz Transmitter Never worry about interference thanks to the solid control link provided by the 2.4GHz radio system. |
Detailed Engine Compartment A detailed replica engine resides in the rear compartment and hides a small electric motor that realistically turns the belts and pulleys to power the cooling fan when the vehicle is operating. |
Scale Undercarriage The uniquely smooth undercarriage of the original vehicle has been replicated to allow the model to glide over obstacles and protect the running gear during extreme use. |
Fully Capable Crawler Thanks to a 2-speed transmission and selectable RWD/AWD function, the Kubelwagen is not only incredibly detailed, but also a capable off road machine. |
- Four-wheel independent suspension
- Rear portal axles
- Front and rear axle planetary gear differentials
- Scale air-cooled, horizontally opposed four-cylinder engine
- Hidden electric motor powers a belt-driven engine cooling fan
- Third channel two-speed transmission control
- Fourth channel selects between 4WD-RWD mode
- Retractable windscreen
- Servo-operated steering wheel provides synchronized movement with front wheels
- Four openable doors with mechanical locks
- Soft fabric seats front and rear with stowable rear seats
- Spacious luggage compartment with openable hatch
- Headlamps, ant-aircraft light, turn signals, and brake lamp LED set
- Realistic 5.25-16 tires, wheels, and spare tire
- Metal front and rear bumpers
- Perfect for 1/12 figures
- 30 pc. stainless steel ball bearings included
- Metal transmission and differential gears
- Metal drive shafts and axles
- Authentic World War II German grey paint scheme
- Realistic pad-printed body logo details
- Four-channel 2.4Ghz digital proportional remote control system
- ROC Hobby Kubelwagen 1/12 Scale 4WD Military Truck - RTR
- ROC Hobby 2.4GHz Pistol-Grip Transmitter
- ROC Hobby 2-in-1 RX/ESC
- ROC Hobby Steering Servo
- ROC Hobby Steering Wheel Servo
- ROC Hobby 2-speed Shift Servo
- ROC Hobby Hi-Torque 180-size Brushed Motor
- 7.4V 380mAh LiPo Battery
- USB battery Charger
- 4x AAA Alkaline batteries for transmitter
AGE LEVEL :14 and up
SKILL LEVEL :beginner
BUILD TIME :less than 15 minutes
| Model Scale | 1/12 |
| Length | 317mm / 12.4in |
| Width | 135mm / 5.3in |
| Height | 129mm / 5in |
| Weight (No Battery) | 635g / 22.7in |
| Wheelbase | 202mm / 7.8in |
| Ground Clearance | 30mm / 1.2in |
| Body | Injection molded ABS plastic, factory painted |
| Chassis | Metal/Composite scale-type |
| Drivetrain | 2WD-4WD |
| Wheel Size (Diameter x Width) | 58mm x 12mm |
| Wheel Hex Size | N/A |
| Tire Tread | Scale |
| Bushing Material | N/A |
| Suspension | Torsion spring |
| Shock Type | N/A |
| Transmission | |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | Yes (metal geared) |
| Ball Bearings | Yes |
| Brakes | Electronic |
| Electronic Speed Control | Brushed 2-in-1 RX/ESC (included) |
| Motor | 180-size brushed |
| Battery | 7.4V 380mAh LiPo |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 3x 1Kg High-Torque Servos |
| Radio | 2 Channel |
| Lights | Yes |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Beginner |
| Assembly Time | Less than 15 minutes |
| Recommended Environment | Indoors/Outdoors |
