Official FMS FCX24 Power Wagon 1/24 Scale 4WD Crawler Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    FCX24 Power Wagon 1/24 Scale 4WD Crawler - RTR from FMS
    Click image for larger version  Name:	fms-fcx24-power-wagon-blue.jpg Views:	0 Size:	115.4 KB ID:	353063
    Click image for larger version  Name:	fms-fcx24-power-wagon-red.jpg Views:	0 Size:	121.3 KB ID:	353064
    Click image for larger version  Name:	fms-fcx24-power-wagon-yellow.jpg Views:	0 Size:	115.0 KB ID:	353065
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter.
    The FMS FCX24 Power Wagon 1/24 Scale 4WD Crawler RTR from Motion RC is a new, innovative option in small-scale RC crawlers, offering several features that are brand-new to the category! An ideal choice for both indoor and outdoor scale adventure, the high-performance chassis utilizes high-strength nylon instead of the traditional trapezoidal beam design with metal rails for lighter weight and improved durability. A mid-mounted power system contains a servo-controlled 2-speed transmission, transfer case, and 130-sized motor for a lower CG and enhanced climbing performance. The 2-speed transmission allows drivers to conveniently switch on the fly between a crawling ratio (99:1) or high-speed ratio (24.75:1) directly from the transmitter. Of course, a vehicle of this caliber is delivered with 24 stainless steel, aerospace-quality ball bearings as standard equipment. No plastic or metal bushings here!
    Perhaps the most innovative feature of the FCX24 are portal axles that provide additional torque, overall performance, and improved approach and departure angles. The included 4 channel 2.4 GHz pistol-grip transmitter also provides LED headlight control, voltage cutoff settings, or select from four options of drag brake settings for the ultimate small-scale crawling experience.
    The injection-molded polystyrene body shell evokes styling cues from late 1940’s-era mud trucks, and is attractively painted in your choice of red, yellow, or blue. An injection-molded nylon rear cage with included spare wheel and tire allows for infinite customization and personalization opportunities with the addition of various bed, tarp, or cover options (available separately).
    Enjoy the next small thing in radio control by combining the versatile, go-anywhere fun of FMS FCX24 Power Wagon Red 1/24 Scale 4WD Crawler with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    Portal Axles
    The use of portal axles allows for additional reduction of FDR (final drive ratio) and delivers enhanced ground clearance for unsurpassed crawling ability.
    Composite Chassis and Links
    The strong but lightweight chassis rails and links are complimented by heavy-duty steel CVD-style drive shafts for durability and optimized torque transfer.
    Combination Receiver/ESC
    The full-featured RX/ESC unit contains additional ports to allow users to add taillights, fog lights, and turn signals in addition to the included headlight LED lamps. The ESC is user-programmable to tailor acceleration, hold, and brake forces toward a crawling or rock racing setup.
    Metal-Geared Steering Servo
    The FCX24 contains a best-in-category metal-geared steering servo that allows you to traverse, crawl, climb, or race with confidence!
    • Authentic full-time 4WD with 2-speed transmission
    • Metal-geared steering servo
    • Injection-molded polystyrene body
    • Portal axles
    • Complete ball bearings
    • 4 channel pistol-grip 2.4GHz transmitter
    • Powerful 130-size brushed motor
    • Oil dampers
    • Durable nylon composite chassis
    • LED headlights
    • Metal CVD-style driveshafts
    • 68° approach angle, >90° departure angle
    • FMS FCX24 Power Wagon Blue 1/24 Scale 4WD Crawler - RTR
    • FMS 2.4GHz Pistol-Grip Transmitter
    • FMS 2-in-1 RX/20A ESC (installed)
    • FMS Metal-Geared Steering Servo (installed)
    • FMS 2-speed Shift Servo (installed)
    • FMS Hi-Torque 180-size Brushed Motor
    • 7.4V 380mAh LiPo Battery
    • USB battery Charger
    Requires:
    • 4x AAA Alkaline batteries for transmitter
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 15 Minutes
    Model Scale 1/24
    Length 210mm / 8.2in
    Width 124mm / 4.8in
    Height 132mm / 5.2in
    Weight (No Battery) 390g / 13.9oz
    Wheelbase 138mm / 5.4in
    Ground Clearance 26mm / 1in
    Body Injection molded ABS plastic, factory painted with clear windows
    Chassis Composite scale-type
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 60mm x 20mm
    Wheel Hex Size N/A
    Tire Tread Scale
    Bushing Material N/A
    Suspension Metal leaf spring
    Shock Type Oil damper
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio 84:1
    Pinion N/A
    Spur Gear N/A
    Differential Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Brushed 2-in-1 RX/ESC
    Motor 180-size brushed
    Battery 7.4V 380mAh LiPo
    Servos 2 (steering and shift)
    Radio 4 channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 15 minutes
    Recommended Environment Indoors/Outdoors
    Are yall bringing back all fms or just the surface line?
