Official Diecast Masters 1/16 Scale Western Star 49X Dump Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The Western Star 49X Dump Truck is a modern truck built to deliver dependability and safety for construction, logging, and hauling operations. This officially licensed replica from Diecast Masters pairs perfectly with other 1/16 scale models for a realistic scale worksite! This model features an operating dump bed, functioning headlights, taillights, and turn signals in addition to a realistic sound system. A rechargeable 2S 2000mAh battery and convenient USB charger, in addition to included AAA alkaline transmitter batteries create a truly comprehensive package.
    Combine this incredible diecast operating replica with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    • 2.4GHz radios system for reliable, interference-free operation
    • Operable dump bed
    • Functioning headlights, taillights, and turn signals
    • Realistic sound system
    • Rechargeable 2000mAh battery provides 45-60 minutes of operation
    • Convenient USB charger
    • Load capacity of 11 bs. (5kg)
    • Diecast Masters 1/16 Scale Western Star 49X Dump Truck - RTR
    • 2.4GHz transmitter
    • 2000mAh Lithium battery
    • USB Charger
    • Instruction manual
    • AAA alkaline transmitter batteries
    Requires:
    • Nothing, everything is included!
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 15 Minutes
    Scale 1/16
    Length 615mm / 24"
    Width 192mm / 7.5"
    Height 230mm / 9"
    Weight 3,050g / 6.7 lbs
    Maximum Cargo Weight 5,000g / 11 lbs
    Wheelbase N/A
    Ground Clearance N/A
    Body Metal and plastic, factory painted and decorated
    Chassis Metal and plastic
    Drivetrain 2WD
    Wheel Hex Size N/A
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension Beam-style
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes Electronic
    Electronic Speed Control Included
    Motor Brushed
    Battery 2S LiPo (included)
    Servos 1
    Radio 2-Channel (included)
    Lights Yes
    Sound Yes
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less Than 15 Minutes
