Official FMS Hummer H1 1/12 Scale 4WD Truck RTR Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: This truck is delivered as "RTR", however does require 4 x AAA batteries for the transmitter and a 2S 7.4V 2000mAh LiPo battery with XT30 connector and appropriate charger sold separately (see Requires below for details).
    The durable, multi-purpose Hummer H1 has been faithfully recreated in 1/12 scale by FMS! Officially licensed by GM, this realistic masterpiece features a scale suspension system coupled with a two-speed, 2WD/4WD metal-geared drivetrain that can be remotely shifted on the transmitter. Differential lock allows the Hummer to powerfully tackle tough climbs with additional ground clearance provided by the portal axles. An operating steering wheel accents the realistic interior, with operating door latches, removable roof, folding windscreen, and more. A transmitter-controlled front/rear/all-wheel steering function makes this model uniquely maneuverable and fun to drive, while the included 20-LED light set provides yet another layer of realism. The hood even unlatches to reveal a scale engine whose fan assembly operates when the model is turned on!
    Enjoy an impressively realistic RC experience by combining the versatile, go-anywhere fun of the FMS Hummer with Motion RC’s parts and technical support, industry-leading customer service and product selection for a package that cannot be beat!
    Supremely Detailed
    The H1 Hummer contains a 20 pc. LED light set in addition to scale touches such as wipers, mirrors, hood latches, and more!
    Removable Roof
    The top roof panels are removeable to provide access to the superbly detailed interior for display or convenient addition of 1/12 crew figures (not included).
    Scale Chassis Design
    This officially licensed product delivers a realistic chassis design with rock guards and additional scale details.
    Realistic Interior
    Opening doors with operational door handles swing open to reveal a stunningly realistic interior, providing a model that is suited to running or display!
    Portal Axles
    Equipped with precision off-road portal axles, the chassis has improved minimum ground clearance.
    Metal Components
    The Hummer H1 has a metal driveshaft and gears and is equipped with 47 ball bearings.
    • Assembled, ready to run model
    • Scale interior with servo-operated steering wheel
    • Innovative two-speed, 2WD/4WD transmission
    • Portal axle system with metal gears
    • High ground clearance chassis configuration
    • Hydraulic shock absorber system
    • Scale suspension system
    • Removeable roof panels
    • Opening doors with operating latches
    • Remotely controlled 20-piece LED lighting system
    • High torque, metal-geared steering servo
    • FMS Hummer H1 Black 1/12 Scale 4WD Truck - RTR
    • 2.4GHz Transmitter
    • 2-in-1 Receiver / 40A ESC (installed)
    • 370 Brushed Motor (installed)
    • 9g Plastic Gear Digital Servo x 3 (installed)
    • 13Kg Metal Gear Digital Servo x 2 (installed)
    • Product Manual
    Requires:
    • 4x AAA Alkaline batteries for transmitter
    • 2S 7.4V 2000mAh LiPo Battery with XT30 connector
    • 2S LiPo battery charger
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/12
    Length 408mm / 15.9in
    Width 222mm / 8.6in
    Height 162mm / 6.3in
    Weight (No Battery) 1,510g / 54oz
    Wheelbase 272mm / 10.6in
    Ground Clearance 40mm / 1.6in
    Body ABS Plastic, factory painted and decorated
    Chassis Composite
    Drivetrain 2WD/4WD
    Wheel Size (Diameter x Width) 24.5mm x N/A
    Wheel Hex Size 7mm
    Tire Tread Multi-surface
    Bushing Material Ball bearings
    Suspension 4-wheel, independent
    Shock Type Spring dampers
    Transmission 2-speed, metal gear
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Yes, locking
    Ball Bearings Yes (47)
    Brakes Electronic
    Electronic Speed Control 2-in-1 RX/ESC
    Motor 370 brushed
    Battery 2S 7.4V 380mAh LiPo with XT30 connector (required)
    Max Battery Dimensions (L x W x H) 92 x 36 x 11mm
    Servos 5
    Radio 4-channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
