Official FMS Toyota FJ40 1/10 Scale 4WD Crawler Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Click image for larger version  Name:	fms-toyota-fj40-yellow-1-10-scale-4wd-crawler-rtr-motion-rc-34784985448633.jpg Views:	0 Size:	186.4 KB ID:	384277
    Click image for larger version  Name:	fms-toyota-fj40-blue-1-10-scale-4wd-crawler-rtr-motion-rc-34784743620793.jpg Views:	0 Size:	233.2 KB ID:	384278
    Version Info: This vehicle is delivered as “RTR” but requires the additional purchase of 4 (four) AA alkaline batteries for the transmitter and a 2S LiPo battery (see requires below).
    Motion RC is pleased to offer an outstanding 1/10 scale, officially licensed crawler replica from FMS: the iconic Toyota FJ40. Incorporating a traditional four-link suspension system with metal trapezoidal beams for strength and durability, the model rides confidently on high-grip 1.9” crawler tires with oil-filled, coil-over dampers. A powerful 550-size, 35T brushed crawling motor delivers the torque required to confidently traverse most obstacles, while the impressively detailed, hard plastic body shell features LED lights, opening doors, removable top, retractable cabin bench seats, and opening hood and tailgate. The impressive attention to detail remains evident in the detailed and realistic dashboard, instrument cluster, roof rack, and soft-touch rubber front seats.
    Simply add 4 AA batteries for the interference-free 2.4GHz transmitter, your choice of 2S LiPo battery and appropriate charger to begin your scale crawling adventure.
    Combine the versatile, go-anywhere fun of the FMS Toyota FJ40 Blue 1/10 Scale 4WD Crawler with Motion RC’s industry-leading customer service and product support for a package that cannot be beat!
    Highly Detailed
    The FJ40 features a strong, injection-molded body shell with unsurpassed detail, while interior features and materials deliver impressive scale fidelity.
    Removable Roof Rack
    Explore three options for your scale look: Roof and rack, roof only, or completely open.
    Impressive Interior
    In addition to the detailed dashboard and instrument cluster, the FJ40 also features a synchronized steering wheel that rotates proportionally to the front wheels. Add a 1/10 scale driver figure (not included) for additional realism!
    Metal Ladder Frame
    The solid metal frame rails offer a rugged platform to tackle the toughest terrain or obstacles.
    All-Terrain Tires
    The impressive 1.9” crawler tires provide the forward grip and side bite required to ascend the most challenging inclines or downhills.
    Durable Drivetrain
    Hex hardware and metal driveline components ensure reliability, durability, and maximum performance.
    • Full-time 4WD, assembled and ready-to-run
    • Complete ball bearings
    • Detailed, injection-molded hard plastic body shell
    • Four-link suspension system
    • Realistic interior with soft rubber seats
    • Opening hood, side doors, and tailgate
    • Metal frame rails
    • 1.9 inch All-Terrain tires
    • Brushed 35T 550-size crawler motor
    • LED light set
    • FMS Toyota FJ40 Yellow 1/10 Scale 4WD Crawler - RTR
    • 2.4GHz 4 channel transmitter
    • 2-in-1 receiver / 40A ESC (factory-installed)
    • 550 brushed motor (factory-installed)
    • 9g plastic digital servo (factory-installed)
    • 15kg metal digital steering servo (factory-installed)
    • Product manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 15 Minutes
    Model Scale 1/10
    Length 571mm / 22.4in
    Width 268mm / 10.5in
    Height 326mm / 12.8in
    Weight (No Battery) N/A
    Wheelbase 339mm / 13.3in
    Ground Clearance 82mm / 3.2in
    Body Injection molded ABS plastic, factory painted with clear windows
    Chassis Metal/Composite scale-type
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 115mm x 30mm
    Wheel Hex Size N/A
    Tire Tread All-Terrain
    Bushing Material N/A
    Suspension Four-link
    Shock Type Oil-filled, coil-over
    Transmission 4WD Shaft-driven
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear 42T
    Differential No
    Ball Bearings Full
    Brakes Electronic
    Electronic Speed Control 40A brushed 2-in-1 RX/ESC (included)
    Motor 35T 550-size brushed
    Battery 7.4V LiPo (not included)
    Servos 2
    Radio 2.4GHz 4 Channel
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 15 minutes
    Recommended Environment Indoors/Outdoors
  • RacerXXX
    • Jul 2023
    • 11
    It's great that you do reviews! It's not so great that the threads die and no help ever comes from someone buying a product based on your review.
    • Naveda08
      • Dec 2021
      • 38
      • New York
      • Naveda08
        • Dec 2021
        • 38
        • New York
        • Bigbird8GA
          • Jan 2024
          Attention battery issue - might impact your experience.
          1. Admiral 5300mAh 3S 11.1V 60C Hard Case LiPo Battery with XT60 Connector - Does not work with the FMS FJ40.
          2. I reached out to FMS and suggested they share the battery dimension to save time for future customers.
          3. To the best of my understanding the Max Battery size that fits is - 6" X W2" X L2"
          Any specific Battery recommendations that actually work ??
          • jbaartz
            • Sep 2020
            • 488
            Thanks for pointing this out. The recommended 2S battery will fit. That can be found here.
