Official Primus Primus PC10 1/10 Scale 4WD Crawler Discussion Thread
  • Official Primus Primus PC10 1/10 Scale 4WD Crawler Discussion Thread
    Click image for larger version  Name:	primus-pc10-blue-1-10-scale-4wd-crawler-rtr.jpg Views:	0 Size:	155.1 KB ID:	412306
    Click image for larger version  Name:	primus-pc10-white-1-10-scale-4wd-crawler-rtr.jpg Views:	0 Size:	155.0 KB ID:	412308
    Click image for larger version  Name:	primus-pc10-matte-green-1-10-scale-4wd-crawler-rtr.jpg Views:	0 Size:	152.4 KB ID:	412309
    Version Info: Fully assembled, decorated, and ready-to-run, this model requires a 1000-5000mAh 7.4V 2S LiPo battery with XT-60 connector and 4 AA alkaline batteries for the transmitter.
    Now available from Motion RC, the surprisingly affordable Primus PC10 1/10 scale crawler will surprise you with its lengthy list of standard features! Metal-geared portal axles deliver increased torque, improve approach and descent angles and deliver ideal wheel speed for a superior crawling experience, while the shift-on-the-fly 2-speed transmission delivers climbing torque or top speed. An innovative magnetic body mount system offers convenient and easy access to the generously sized battery tray, offering endless options for weight, run time, and handling tweaks offered by using packs of different size and weight. The factory-painted polycarbonate body shell arrives in your choice of four colors and includes additional molded plastic details like bumpers, guards, mirrors, and more. The powerful, water-resistant brushed motor, Hobbywing 40A Crawler ESC, and bearing-equipped drivetrain deliver a reliable and enjoyable crawling experience.
    Elevate your crawling game by combining the versatile, durable, capable crawling performance of the Primus PC10 1/10 Scale 4WD Crawler with Motion RC’s industry-leading customer service, product selection, and complete parts support for a package that cannot be beat!
    Complete Package
    The 1/10 scale Primus PC10 RTR arrives assembled, decorated, and ready to run. Install your choice of 2S LiPo, add 4 AA alkaline transmitter batteries and be prepared for an exhilarating crawling experience!
    Top-Shelf Equipment
    The Hobbywing 40A crawler ESC accepts 2S LiPo or 6S 7.2v NiMH input for a variety of weight/handling/performance options.
    Durable Drivetrain
    The well-appointed chassis features machined aluminum rails, molded guards, bumpers, and more!
    Plush Suspension
    The Primus crawler features unique metal, oil filled shocks with internal springs for compliant handling and reduced maintenance and cleaning compared with coil-over setups.
    Large Battery Tray
    The generously sized battery tray allows for a wide range of 6S NiMH or 2S LiPo packs to be used. Battery type, size, and capacity (and therefore weight) are an important tool to obtain the perfect handling for any specific condition or trail.
    Convenient Body Mounts
    The magnetic front/swivel rear body mounting system improves accessibility for maintenance or battery changes, without the needs for unsightly and often-lost body clips.
    Comfortable, Reliable Radio System
    The 2.4GHz radio system delivers interference-free performance and useful adjustments to dial-in the crawler exactly the way you prefer!
    Maximum Grip
    The 42 x 116mm ultra-performance crawling tires are mounted on decorative beadlock wheels for enhanced adhesion on a wide array of surfaces and soils.
    Features:
    • Portal axles for additional ground clearance and optimized wheel speed
    • Innovative magnetic tilt-up body mounting system eliminate body clips and improves scale appearance
    • Hobbywing 40A brushed crawler ESC, capable of both LiPo and NiMH operation
    • Model arrives fully decorated and ready to run
    • Shift-on-the-fly 2-speed transmission
    • Proven four-link chassis design with aluminum main rails and shocks with internal springs and dust covers
    • Shaft-driven 4WD system
    • Robust chassis links and tie rods for exceptional durability
    • Reliable and responsive 2.4GHz radio gear
    • 550 brushed crawler motor
    • Complete ball bearings
    • Accepts a wide range of battery packs for convenience and flexibility
    • Unique steering damper improves precision and reliability
    • Available in four unique colors
    • Molded front and rear bumpers, fender guards, roll hoop, bed guard, mirror, snorkel and more
    • High-grip crawler tires with functional bead lock wheels
    Includes:
    • Primus PC10 Blue 1/10 Scale 4WD Crawler - RTR
    • 2.4GHz transmitter
    • Quick start guide
    • Tools and spare parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 30 Minutes
    Model Scale 1/10
    Length 543mm / 21.2in
    Width 248mm / 9.7in
    Height 245mm / 9.5in
    Weight (No Battery) 3,500g / 125oz
    Wheelbase 313mm / 12.2in
    Ground Clearance 55mm / 2.1in
    Body Polycarbonate, factory painted and decorated
    Chassis Aluminum
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 116 x 42mm
    Wheel Hex Size 12mm
    Tire Tread All-terrain
    Bushing Material N/A
    Suspension Four-link with dampers, solid axles
    Shock Type Oil-filled, internal spring
    Transmission Gear
    Gear Pitch M0.8
    Internal Gear Ratio 3.09:1
    Final Drive Ratio Lo 37:1, Hi 15:1
    Pinion 11T
    Spur Gear 34T
    Differential Locked
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control Hobbywing 40A with XT60 connectors
    Motor 550 brushed
    Battery 2S with XT60 connector (required)
    Max Battery Dimensions (L x W x H) 140mm x 48mm x 30mm
    Servos Waterproof, metal gear, 15Kg
    Radio 2-channel (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 30 minutes
    definitely a fun little truck
      trail run
        Post reported.
          Can you shift the 2-speed transmission on the radio?
            yep
ID:	443500 Click image for larger version
ID:	443501 So, after the snow hit the ground and the thermometer went below zero, I decided to start tearing into this thing make a few improvements. Pretty much beyond my skills to make proper headlights for it, so I settled for lights in the bumper mounted housings after painting the inside silver and turn signals in the bumper itself and tail/turn/bu in the rear bumper, still need to make lens for that.
              Swapped out the radio for a DumboRC P6DCG so it will work with my DDF-350 and the built in light controller do what it do, also swapped out the riculously stiff shocks for some Injora DRX 90mm, got new rims, tires are still enroute, going down from a 118mm to a 110mm, just think the oem's are a bit too big, remote lockers are in the works too.
                Ended up going with a more retro style rim, the tires are 110mm, I might end up going even smaller if I can find one I like, pretty much a trailer runner so I'd like going more stock, but they're better than clown wheel setup it had before.
ID:	443637 Click image for larger version
                  And now the Primus PC10 MJ, just couldn't take the body anymore, have the rear hinged after chopping the frame a bit, should be able to use the original front magnet setup, had to cut the bed to clear the rea shocks/tower, cargo will hide that
