Official Primus Primus PC10 Pro D110 1/10 Scale 4WD Crawler Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: Fully assembled, decorated, and ready-to-run, this model requires a 1000-5000mAh 7.4V 2S LiPo battery with T connector and 4 AA alkaline batteries for the transmitter.
    Now available from Motion RC, the affordable yet supremely featured Primus PC10 Pro 1/10 scale crawler will surprise you with its looks and performance! Outfitted with independently locked or open front and rear differentials, the PC10 Pro can successively traverse the toughest climb or torque through a narrow crevasse. Metal-geared portal axles deliver increased torque, improve approach and descent angles and deliver ideal wheel speed for a superior crawling experience, while the shift-on-the-fly 2-speed transmission delivers climbing torque or top speed. The realistic molded plastic body, fender guards, and accessories combine to make this model not only a stunning display piece, but a credible, performance-oriented crawler. The included LED light set brings the realism of this replica to new levels while the powerful, water-resistant 550 brushed motor, Hobbywing 60A Crawler ESC, and bearing-equipped drivetrain deliver a reliable and enjoyable crawling experience.
    Elevate your crawling game by combining the versatile, durable, capable crawling performance of the Primus PC10 Pro 1/10 Scale 4WD Crawler with Motion RC’s industry-leading customer service, product selection, and complete parts support for a package that cannot be beat!
    Durable Drivetrain and Robust Undercarriage
    The well-appointed chassis features machined aluminum rails, while the fender guards, bumpers, and side guards combine to keep equipment dry and free from dirt and debris.
    Plush Suspension
    The Primus PC10 Pro crawler features aluminum, oil filled, coil-over shocks with preload adjusters for compliant handling.
    LED Lights
    The factory installed LED lighting system modes are selectable via the transmitter, allowing for turn signals, hazard flashers, headlight brightness and more.
    Intelligent Equipment Layout
    The PC10 Pro features an organized and neat equipment layout, while the generously sized battery compartment allow for a wide range of battery capacities.
    Comfortable, Reliable Radio System
    The 2.4GHz radio system delivers interference-free performance and useful adjustments to dial-in the crawler exactly the way you prefer!
    Maximum Grip
    The 42 x 116mm ultra-performance crawling tires are mounted on decorative beadlock wheels for enhanced adhesion on a wide array of surfaces and soils.
    Complete Package
    The 1/10 scale Primus PC10 Pro D110 RTR arrives assembled and ready to run. Install your choice of 2S Lipo, add 4 AA alkaline transmitter batteries and prepare yourself for an exhilarating crawling experience!
    Detailed Interior
    A fully detailed interior elevates scale realism and easily accepts a wide variety of optional 1/10 scale driver and passenger figures.
    • Portal axles for additional ground clearance and optimized wheel speed
    • Molded plastic body with opening doors and detailed interior
    • Independently lockable (from transmitter) front and rear differentials
    • Hobbywing 60A brushed crawler ESC, capable of both LiPo and NiMH operation
    • Model arrives fully decorated and ready to run
    • Shift-on-the-fly 2-speed transmission
    • LED light system, selectable from the transmitter
    • Proven four-link chassis design with aluminum main rails and adjustable aluminum, oil-filled, coil-over shocks
    • Shaft-driven 4WD system
    • Robust chassis links and tie rods for exceptional durability
    • Reliable and responsive 2.4GHz radio gear
    • 550 brushed crawler motor
    • Complete ball bearings
    • Accepts a wide range of battery packs for convenience and flexibility
    • Unique steering damper improves precision and reliability
    • Available in two attractive colors
    • Molded front and rear bumpers, fender guards, mirrors, and more!
    • High-grip crawler tires with functional bead lock wheels
    • Primus PC10 Pro D110 Silver 1/10 Scale 4WD Crawler - RTR
    • 2.4GHz transmitter
    • Quick start guide
    • Tools and spare parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 30 Minutes
    Model Scale 1/10
    Length 543mm / 21.2in
    Width 248mm / 9.7in
    Height 245mm / 9.5in
    Weight (No Battery) 3,500g / 125oz
    Wheelbase 313mm / 12.2in
    Ground Clearance 55mm / 2.1in
    Body Molded plastic composite
    Chassis Aluminum
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 116 x 42mm
    Wheel Hex Size 12mm
    Tire Tread All-terrain
    Bushing Material N/A
    Suspension Four-link with dampers, solid axles
    Shock Type Oil-filled, aluminum coil-ove
    Transmission Gear
    Gear Pitch M0.8
    Internal Gear Ratio 3.09:1
    Final Drive Ratio Lo 37:1, Hi 15:1
    Pinion 11T
    Spur Gear 34T
    Differential Open or locked
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control Hobbywing 60A with T connector
    Motor 550 brushed
    Battery 2S with T connector (required)
    Max Battery Dimensions (L x W x H) 140mm x 48mm x 30mm
    Servos
    • 1x Waterproof, metal gear, 15Kg
    • 3x 9Kg
    Radio 4-channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 30 minutes
  • topher65
    • Feb 2020
    The orange one sure looks like what I have in my garage
    • Zapster2k
      • Apr 2024
      Who is the actual manufacturer of the Primus brand of vehicles? They appear to be of Traxxas and RedCat quality. The proce point is reasonable!
      • Roaming Gnome
        • Aug 2024
        • 141
        So does anyone actually have one of these that they can provide some feedback on it? I'm looking at it and the FMS FCX10 Pro at about $60, and I spoke with support at FMS and the guy stated that it wasn't a crawler in the classic sense, I'm looking for something that run trails at a brisk walking speed and go off trail for a bit of exploring.
        • Roaming Gnome
          • Aug 2024
          • 141
          Just ordered one in silver, I guess we'll see what we see.
          • Roaming Gnome
            • Aug 2024
            • 141
            Well we got it.
            Seems well built, my initial disappointments are a lack of documentation beyond a
            "quick start" guide, lack of a spare tire despite there being a place for one that looks crappy without it and despite the ad stating turn signals as one of the lighting features, the only modes are on off or flashing and a pronounced, persistent leaning to the right which will probably take a quick adjustment of the shocks.
            All in all I'm happy with what I got, and after a bit of research, I found at German company that sells the same model under a different brand, Absima Landim with conplete documentation on their website
            Click image for larger version  Name:	landrover_a.jpg Views:	0 Size:	127.4 KB ID:	423803
            Click image for larger version  Name:	20250410_154852.jpg Views:	0 Size:	332.7 KB ID:	423810 Click image for larger version  Name:	20250410_155042.jpg Views:	0 Size:	128.4 KB ID:	423811
            • glocke12
              • Mar 2025
              • 59
              I have the orange one, and my initial thoughts are compared to Traxxas, its a better value for the money in terms of the overall package.
              The lack of turn signals is kind of lame, and the blinking hazard lights are bound to send me into a seizure so im not sure what the point of those are. The lack of a spare tire didnt bother me until you pointed it out, but I think I found a solution to that.
              https://www.ebay.com/itm/164851501982
              I haven't really done anything but drive it around the inside of my house. I live on a pretty swampy piece of land here in eastern PA and am waiting for things to dry out before I take this outside.
              Originally posted by Roaming Gnome
              Well we got it.
              • Roaming Gnome
                • Aug 2024
                • 141
                I was going to get the orange one originally, but I changed my mind, paint is in the future anyway, it's also sold under the Yikong brand in fact the steering servo has a Yikon label on it. Thanks for the link, just got one, as soon as the batteries charge heading for a park close by with some trials ")
                • Roaming Gnome
                  • Aug 2024
                  • 141
                  Apparently some clown is drop shipping from MRC and just jacking up the price to a stupid level
                  https://www.ebay.com/itm/40574932607...MAAOSw6xRn-Ev2
                  • Roaming Gnome
                    • Aug 2024
                    • 141
                    Got the tire, came with the 3 point mount for the Sherpa, but the brass stud and everything else was usable with the stock mounting plate. One caveat, when I removed the screws for the mounting plate it took the plastic with it on a couple so they really wouldn't tighten back up, I'm guessing they just spun them in at the factory and melted the p;astic or just stripped the hole. No biggy, CA glue and it's all goClick image for larger version
ID:	424615od and looks great
