Official Primus DT16 Cheetah 1/16 Scale Brushless 4WD Truck Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: Fully assembled and ready-to-run, this model requires the addition of 3 AA alkaline batteries for the transmitter (not included).
    Mini model bashers with the need for speed will enjoy the new Primus DT16 Cheetah 1/16 Scale 4WD Brushless Truck, now available exclusively from Motion RC! This compact, feature-packed truggy includes a powerful brushless motor, complete ball bearings, heavy-duty drivetrain, high-downforce rear wing, optional wheelie bar, LED lights, and more! A convenient transmitter switch even allows for maximum throttle settings to be limited for younger drivers or new enthusiasts not quite ready to handle the blistering top speeds of the DT16 Cheetah, while the high grip, all-terrain tires deliver maximum grip on dirt, concrete, or tarmac.
    Elevate your bashing game without depleting your wallet by combining the versatile, durable, insanely fast performance of the Primus DT16 Cheetah 1/16 4WD Brushless Truck with Motion RC’s industry-leading customer service, product selection, and complete parts support for a package that cannot be beat!
    Ready for Action
    The 1/16 scale Primus DT16 Cheetah arrives assembled and ready to run. Install 3 AA alkaline transmitter batteries and prepare for an amazing driving experience!
    Intelligent Chassis Layout
    Inspired by successful 1/8 scale buggy and truggy designs, the DT16 Cheetah includes a metal chassis top brace for improved rigidity and drivetrain alignment, complete ball bearings, and heavy-duty steering servo.
    Plush Suspension
    Coil-over composite dampers with adjustable tensioner clips allow for precise ride height and travel adjustments and deliver impressive handling on a wide range of conditions and surfaces.
    Smooth Underside
    The DT16 Cheetah chassis has a smooth underside that utilizes captured pins, allowing for low ride heights without fear of casing jump faces or being beached by debris.
    Included Optional Wheelie Bar
    The impressive torque from the 2847 4000kV motor can occasionally deliver unwanted wheelstands or backflips. Protect against those unwanted stunts with the included wheelie bar.
    Multi-Mode LED Lights
    Bright LED headlamps illuminate the road in low light conditions, with various modes selectable from a convenient transmitter button.
    • Fully assembled and ready to run
    • 4WD with metal-geared differentials
    • Complete ball bearings
    • High downforce molded rear wing
    • Powerful 2847 brushless motor and integrated ESC/RX
    • Durable metal center driveshaft and dogbones
    • Optional wheelie bar included
    • Lightweight, durable polycarbonate body available in two attractive colors
    • Multi-mode LED headlights
    • Lo-Med-Hi Speed TX throttle selector allows for younger drivers to learn without danger or damage
    • Primus DT16 Cheetah Orange 1/16 Scale Brushless 4WD Truck - RTR
    • 2.4GHz transmitter
    • 2S 7.4V Li-ion battery
    • USB charger
    • Quick start guide
    • Damper spring preload clips
    • Tools and spare parts
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 30 Minutes
    Model Scale 1/16
    Length 300mm / 11.8in
    Width 235mm / 10.0in
    Height 115mm / 5.0in
    Weight (No Battery) 993g / 36oz
    Wheelbase 185mm / 8.0in
    Ground Clearance 36mm / 1.4in
    Body Polycarbonate, painted and decorated
    Chassis Composite
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 85 x 46.5mm
    Wheel Hex Size 12mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension Independent, double wishbone
    Shock Type Coil-over friction dampers
    Transmission Direct drive
    Gear Pitch M0.2
    Internal Gear Ratio 3:1
    Final Drive Ratio 7.66:1
    Pinion 18T
    Spur Gear 46T
    Differential Metal gear planetary
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control 35A with T-connector
    Motor 2847 brushless
    Battery 2S 7.4V 1500mAh lithium-ion (included)
    Max Battery Dimensions (L x W x H) 71 x 36.5 x 18.5mm
    Servos Waterproof
    Radio 2-channel (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time Less than 30 minutes
