Official RotorScale AH-6 Attack 450 Size Helicopter Discussion Thread
    • 2818
    • Arlington, TX
    Originally posted by DCORSAIR
    AH-6-5 blades, OH-6-4 blades, good job Delta for your links you always provide for us, one day I may get one of those little 450 or 500 scale helis to fly.
    Thanks D, happy to help. I swear finding parts is one of the most difficult parts of building scale helis. As for your breakdown, yes-ish. The blade count does slightly depend on the model of either.
    4 blade rotor/ 2 blade tail: OH-6A, B, J, TH-6B, AH/MH-6C
    5 blade rotor/ 2 blade tail: AH/MH-6E, F, G, H, J
    5 blade rotor/ 4 blade tail: Hughes 500P "The Quiet One" CIA version
    6 blade rotor/ 4 blade tail: MH/AH-6M, AH-6I
    • Gravythe clown
      • Mar 2019
      • 711
      • Clovis, California
      Just finished up my rebuild. I had an old AH-6 450 that I bought complete years ago. It was on 3S which I don’t have anything else that uses this size of 3s. Also a couple years ago a guy at our field flew into it, while sitting in the pit, and smashed up the glass on the canopy. A buddy did a temp fix but it finally gave out.
      so I decided to change out the fuse with a new AH-6. Just finished it up. I hope to get it back in the air as soon as weather lets me.
      next is to repaint my 450 500E police to Fresno County Sheriff.
      Gravy​
      • GunnyG
        • Mar 2025
        • 3
        • Camden, SC
        Hi All,
        Just got this heli from Motion RC, along with a Microbeast Ultra, and running on a Futaba T6K-V3S 8-channel radio.
        Just getting back into helis, after a LOOONNNGGG hiatus (my last heli was a Kyosho Concept 30DX with a Hughes 500 fuse! Late 80's/early 90's ). Any thoughts on initial settings/setup for the Microbeast Ultra? Also, any idea what scale this AH-6 actually is?
        Thanks,
        The Gunny
        • GunnyG
          • Mar 2025
          • 3
          • Camden, SC
          Is anyone still on here??? :ghost:
          • poochies
            • Dec 2014
            • 22
            Gunny you ever get the scale ? Trying to get the crew members printed at right size …. I’m thinking 1/12 -1/13 th… thx
            • poochies
              • Dec 2014
              • 22
              Here she is heavily modded got a 4 bladed head and skinny Roban ‘470 ‘ bell 407 blades , reversed the one way bearing so blades spin proper direction moved tail rotor onto proper side made the angled horizontal stab out of balsa , using spectrum 6250 and align 45 amp esc , went to 6 cells ( 2 , 3s 1550’s in series pushed into belly ) to get a constant 17 -18 volts at hover with throttle curve . Flys great very nimble and stable . Took a while to get tail rotor stable with the 6250 had to move adjustments up and down trial and error way . The pilots are bought from 3d print file site and scaled to 1/11-12 about 6 inches high. Scratch built cockpit 3D printed instrument panel ( from same site ) with aluminum glareshield over it , Callie graphics miss clawd scaled to 1/10th( she had on file already ) . Rotor rpm at hover roughly 2000 on 6s since blades are scale , thin cord . Was a fun project .i can put more photos up or answer any questions . I had to get the kit from motion rc Europe since no stock in USA forever . If came surprisingly quick but had a few cracks in fuselage / windscreen which I fixed best I could .
              • poochies
                • Dec 2014
                • 22
                Oh forgot I cut about 5/8in out of each landing struts and drilled holes and cut down old Allen keys to join pieces adds lots of strength , this lowered it a lot makes it look more like the old Cayuse , then I cut some plywood away at an angle where the struts mount into so the struts sit wider with weight on them . Added nav lights with an anti collision light on top and white Landing light in front of lower windscreen /canopy , the light unit is plugged into aux of the 6250. I believe the light unit is from the Roban Huey kit .
